    Dismiss Notice
Flash tubes
Discussion in 'High Voltage' started by Dr_Doggy, Dec 30, 2016.
  1. Dr_Doggy
    Dr_Doggy Well-Known Member
    Aug 11, 2007
    1,656
    37
    ONLINE
    https://upload.wikimedia.org/wikipe...flash-lamp.svg/440px-Xenon-flash-lamp.svg.png
    I assume that the bottom side would be ground, and the other is obviously the high current side, also we can see where the high voltage trigger is as well...
    but how does this trigger work, it seems to me that it has a path to the ground, but an even shorter path is the one to the high current capacitor, what happens when a trigger pulse finds its way and discharges to the +ve side of the capacitor first? and if it did/does, how is it able to find its way to ground and complete the flash(discharge of capacitor)??
  2. ericgibbs
    ericgibbs Well-Known Member Most Helpful Member
    Jan 4, 2007
    20,742
    620
    Ex Yorks' Hants UK
  3. Dr_Doggy
    Aug 11, 2007
    1,656
    37
    ONLINE
    so I do not need to worry about t2's kv charge causing spikes on C3 and R2?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Dr_Doggy
    Aug 11, 2007
    1,656
    37
    ONLINE
    ok so i got polarity wrong,!
    BUT, if we measure resistance as a ratio between A & K , then the anode is about 10x the distance the cathode from the kv trigger, which means about 10% of the trigger current will make it over to C3,,
    again is this a problem or is the trigger current insignificant enough (and/or capacitor large enough ) to handle the shock from the trigger charge?
    also if C3 is absorbing the trigger charge, how is it able to ionize the tube and complete the circuit?
Share This Page
