    Dismiss Notice
External Interrupt on GP2
Discussion in 'Microcontrollers' started by Suraj143, Oct 25, 2017.
  1. Suraj143
    Suraj143 Active Member
    Jan 11, 2007
    1,580
    2
    South Mald Isld
    I'm receiving a continuous 5V square wave pulse 50Hz. I want to detect High to low transition (Falling edge) on GP2.
    My question is Do I need to enable internal WPU on GP2? I use PIC12F675.
  2. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,084
    326
    Brisbane Australia
    ONLINE
    If you use the IOC (Interrupt on change) function on GP2 then if, when the interrupt triggers, the pin is low it must have just transitioned. You need the WPU if the signal is active low only.
  3. Suraj143
    Jan 11, 2007
    1,580
    2
    South Mald Isld
    I need to use INTF external interrupt flag bit.I set INTEDG to falling edge.In this case do I need the internal WPU enable?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Pommie
    Mar 18, 2005
    10,084
    326
    Brisbane Australia
    ONLINE
    If your signal is driven high then WPU not needed. If open collector then WPU needed. Either way you can enable WPU as it can't do any harm.
  6. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,294
    647
    Derbyshire, UK
    ONLINE
    You only need pull-ups if the source is open-collector, as long as it's a normal logic output then no pull-ups are needed.
Share This Page
