I bought four of these boards for $22. Mine have the blue adjustment trimmer pot at one end.
These things are fickle . One time it will power up a dozen times in a row. The next time it won't output no matter how many times I try.
My test frequency is set to 7.0000 mhz. These AD boards have an on-board low pass filter that kicks in about 30 mhz and provides an output impedance of about 100 ohms.
I've set up three different circuits, each using a 16F690 as controller. I've powered each circuit from external power supply or from the PicKit2. The circuit pulls about 75ma when operating. There is no power supply voltage sag on power up.
The first two circuits employed serial data input for the 40-bit frequency control. In the last circuit I tried using parallel input. This change made no impact on power-up response.
My antenna is a three inch piece of wire. Connecting a high impedance scope or frequency counter doesn't seem to affect power up response.
When it powers up properly, each board is within 100 Hz of test frequency. All the boards show the same propensity towards fickleness.
What am I missing?
What am I missing?
