That is a good idea, thank you.AFAIK, the IC pins are not tapered. They seem to fit in snugly because the all the pins are not in perfect alignment with the holes. If you take the trouble to align them, they will just fall out if you turn the board upside down. Keeping this in mind, you can "snugly" fit in any component with 2 or more leads if you misalign them.
Sometimes, the leads are much smaller than the PCB holes. In such cases, I bend the protruding length sideways to keep the component in place.
He was asking about breadboards, not PCB'sAFAIK, the IC pins are not tapered. They seem to fit in snugly because the all the pins are not in perfect alignment with the holes. If you take the trouble to align them, they will just fall out if you turn the board upside down. Keeping this in mind, you can "snugly" fit in any component with 2 or more leads if you misalign them.
This is the only board I have.
Yes, a breadboard.This is the only board I have.
If you do gravitate to Vero or StripBoard, used for more permanent one-off's after bread board testing.I have not heard of a Veroboard, but I will Google it now.
The supplier in your link certainly has a good selection of board types to choose from. It provides an indication of what is actually available out there beyond 'e bay'If you do gravitate to Vero or StripBoard, used for more permanent one-off's after bread board testing.
You can get it here a quarter way down the page.
Prototyping Boards
Wide Range of Prototyping Boards for Building and Testing Electronic Circuitswww.futurlec.com
"Rapid Electronics" is pretty good; they also have an ebay store.I could do with with identifying UK suppliers who sell similar boards.
*Chinese* resistors, that is. You can still buy name brand resistors like Vishay that have proper size leads, and are made from copper not iron like the Chinese ones.Resistor wires these days are very small you need to use needle nose pliers to keep tiny wires from bending. Tiny wires fall out easy too.
I can't remember the last time I ever saw a resistor with copper wires?, and we only source high quality ones from large UK distributors (usually RS or Farnell).
And like I said, I can't remember the last time I saw one with copper wires - presumably it was back when resistors were huge?, as copper is probably too soft for thin wires, it would be too flexible.Copper, with a tin coating. It's how proper resistors are made. The cheap Chinese ones are iron with, I guess, a tin coating. A magnet proves the difference.
Like I also said, I buy expensive resistors from top quality sources, all have steel wires and stick to a magnet, nothing to do with cheap Chinese ones.
