You can use whatever you have in the range 1k to 6k8.shermaine said:Hi,
Thanks for your reply again. Do i hv to use ur resistance value? Or can i use 1Kohm?
Do you have a multimeter?shermaine said:Can i check with you all, for the pcb mount switch, there are 4 legs so i just connect any one point? And for the dip switch, i got 8 legs, that mean i just connect any 2 of the legs? Please advise. Thanks.
Do you have data sheets for all of the ICs?shermaine said:Thanks! Btw, i need to connect all the clk to 555 timer. I'm not sure which pins i need to connect. Please advise
Let us know who it goes.shermaine said:Hi guys,
Thanks so much for the reply. I have finished the wiring. I'm left with a 9V battery to test it out. Hopefully, things are going to be well! cheers!
