decoder for 8051
Parth86
hello
4 bits can decode 16 things.
5 bits can decode to 32 things,
6 bits can decode 64 things.
etc, etc..
8 bit can decode 256 things
16 bit can decode 512 things
can anyone tell me which decoder is used for 8051 microcontroller ?
Your question doesn't make any sense.
BTW, 16 bits can represent 65536 states - not 512.
ok I want to make table as you shown in your post
actually I want to make table for following example
ram_rd_sel
ram_wr_sel
src_sel1
src_sel2
alu_op
wr = 1'b0;
psw_set
cy_sel
pc_wr
pc_sel
imm_sel
src_sel3
comp_sel
bit_addr ;
rom_addr_sel = OC8051_RAS_DES;
ext_addr_sel = OC8051_EAS_DC;
when all input are 0 then do NOP operation
module decoder (clk, rst, op_in, ram_rd_sel, ram_wr_sel, bit_addr, wr, src_sel1, src_sel2, src_sel3, alu_op, psw_set, cy_sel, imm_sel, pc_wr, pc_sel,
                comp_sel, eq, rom_addr_sel, ext_addr_sel, wad2, rd, write_x, reti,
input clk, rst, eq;
input [7:0] op_in;
output wr, reti, write_x, bit_addr, src_sel3, rom_addr_sel, ext_addr_sel, pc_wr, wad2;
output [1:0] ram_rd_sel, src_sel1, src_sel2, psw_set, imm_sel, cy_sel, pc_sel;
output [2:0] ram_wr_sel, comp_sel;
output [3:0] alu_op;
output rd;
reg reti, write_x;
reg wr,  bit_addr, src_sel3, rom_addr_sel, ext_addr_sel, pc_wr, wad2;
reg [1:0] psw_set, ram_rd_sel, src_sel1, src_sel2, imm_sel, pc_sel, cy_sel;
reg [3:0] alu_op;
reg [2:0] comp_sel, ram_wr_sel;
reg [1:0] state;
reg [7:0] op;
always @(rst or op_in or eq or state or op)
begin
  if (rst) begin
  ram_rd_sel = OC8051_RRS_DC;
  ram_wr_sel = OC8051_RWS_DC;
  src_sel1 = OC8051_AS1_DC;
  src_sel2 = OC8051_AS2_DC;
  alu_op = OC8051_ALU_NOP;
  imm_sel = OC8051_IDS_DC;
  wr = 1'b0;
  psw_set = OC8051_PS_NOT;
  cy_sel = OC8051_CY_0;
  pc_wr = OC8051_PCW_N;
  pc_sel = OC8051_PIS_DC;
  comp_sel = OC8051_CSS_DC;
  bit_addr = 1'b0;
  src_sel3 = OC8051_AS3_DC;
  rom_addr_sel = OC8051_RAS_PC;
  wad2 = OC8051_WAD_N;
    case (state)
      2'b01: begin
    casex (op)
      OC8051_ACALL :begin
          ram_wr_sel = OC8051_RWS_SP;
          src_sel1 = OC8051_ASS_IMM;
          src_sel2 = 2'bxx;
          imm_sel = OC8051_IDS_PCH;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_AJMP : begin
          src_sel1 = OC8051_ASS_DC;
          src_sel2 = 2'bxx;
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_LCALL :begin
          src_sel2 = 2'bxx;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      default begin
          src_sel2 = OC8051_ASS_DC;
          wr = 1'b0;
          bit_addr = 1'b0;
      end
    endcase
    end
    2'b10:
    casex (op)
      OC8051_CJNE_R : begin
          wr = 1'b0;
          pc_wr = !eq;
          pc_sel = OC8051_PIS_ALU;
          comp_sel = OC8051_CSS_DES;
          bit_addr = 1'b0;
        end
      OC8051_CJNE_I : begin
          wr = 1'b0;
          pc_wr = !eq;
          bit_addr = 1'b0;
        end
      OC8051_CJNE_D : begin
          alu_op =OC8051_ALU_NOP;
          wr = 1'b0;
          pc_wr = !eq;
          bit_addr = 1'b0;
        end
      OC8051_CJNE_C : begin
          wr = 1'b0;
          pc_wr = !eq;
          bit_addr = 1'b0;
        end
      OC8051_DJNZ_R : begin
          wr = 1'b0;
          pc_wr = eq;
          bit_addr = 1'b0;
        end
      OC8051_DJNZ_D : begin
          wr = 1'b0;
          pc_wr = eq;
          bit_addr = 1'b0;
        end
      OC8051_JB : begin
          wr = 1'b0;
          pc_wr = eq;
          comp_sel = OC8051_CSS_BIT;
          bit_addr = 1'b0;
        end
      OC8051_JBC : begin
          ram_wr_sel = OC8051_RWS_D;
          wr = 1'b1;
          pc_wr = eq;
          bit_addr = 1'b1;
        end
      OC8051_JC : begin
          wr = 1'b0;
          pc_wr = eq;
          comp_sel = OC8051_CSS_CY;
          bit_addr = 1'b0;
        end
      OC8051_JMP : begin
          wr = 1'b0;
          pc_wr = OC8051_PCW_Y;
          bit_addr = 1'b0;
        end
      OC8051_JNB : begin
          wr = 1'b0;
          pc_wr = !eq;
          bit_addr = 1'b0;
        end
      OC8051_JNC : begin
          wr = 1'b0;
          pc_wr = !eq;
          bit_addr = 1'b0;
        end
      OC8051_JNZ : begin
          wr = 1'b0;
          pc_wr = !eq;
          comp_sel = OC8051_CSS_AZ;
          bit_addr = 1'b0;
        end
      OC8051_JZ : begin
          wr = 1'b0;
          pc_wr = eq;
          bit_addr = 1'b0;
        end
      OC8051_MOVC_DP :begin
          wr = 1'b0;
          imm_sel = 2'bxx;
          src_sel3 = OC8051_AS3_DP;
          bit_addr = 1'b0;
          wad2 = OC8051_WAD_Y;
        end
      OC8051_MOVC_PC :begin
          wr = 1'b0;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_SJMP : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      default begin
          wr = 1'b0;
          bit_addr = 1'b0;
      end
    endcase
    2'b11:
    casex (op)
          src_sel2 = OC8051_ASS_OP2;
          alu_op = OC8051_ALU_PCS;
          wr = 1'b0;
          imm_sel = OC8051_IDS_OP3;
          src_sel3 = OC8051_AS3_PC;
          bit_addr = 1'b0;
        end
          wr = 1'b0;
          bit_addr = 1'b0;
        end
          wr = 1'b0;
          bit_addr = 1'b0;
        end
          wr = 1'b0;
          bit_addr = 1'b0;
        end
          wr = 1'b0;
          imm_sel = OC8051_IDS_OP2;
          bit_addr = 1'b0;
        end
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_RET : begin
          ram_rd_sel = OC8051_RRS_SP;
          src_sel1 = OC8051_ASS_RAM;
          wr = 1'b0;
          pc_sel = OC8051_PIS_SP;
          bit_addr = 1'b0;
        end
      OC8051_RETI : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      default begin
          src_sel1 =OC8051_ASS_DC;
          wr = 1'b0;
          bit_addr = 1'b0;
      end
    endcase
    default: begin
    casex (op_in)
      OC8051_ACALL :begin
          src_sel2 = 2'bxx;
          imm_sel = OC8051_IDS_PCL;
          wr = 1'b1;
          pc_sel = OC8051_PIS_I11;
          bit_addr = 1'b0;
        end
      OC8051_AJMP : begin
          src_sel1 = 2'bxx;
          src_sel2 = 2'bxx;
          alu_op = 4'bxxxx;
          imm_sel = 2'bxx;
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_ADD_R : begin
      ram_rd_sel = OC8051_RRS_RN;
      ram_wr_sel = OC8051_RWS_ACC;
      src_sel1 = OC8051_ASS_ACC;
      src_sel2 = OC8051_ASS_RAM;
      alu_op = OC8051_ALU_ADD;
          wr = 1'b1;
      psw_set = OC8051_PS_AC;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_ADDC_R : begin
          wr = 1'b1;
      cy_sel = OC8051_CY_PSW;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_ANL_R : begin
          alu_op = OC8051_ALU_AND;
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
          alu_op = OC8051_ALU_SUB;
          wr = 1'b0;
          psw_set = OC8051_PS_CY;
          bit_addr = 1'b0;
        end
      OC8051_DEC_R : begin
          ram_wr_sel = OC8051_RWS_RN;
          src_sel2 = OC8051_ASS_ZERO;
          wr = 1'b1;
          cy_sel = OC8051_CY_1;
          bit_addr = 1'b0;
        end
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_INC_R : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOV_R : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end        OC8051_MOV_AR : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOV_DR : begin
          ram_rd_sel = OC8051_RRS_D;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOV_CR : begin
          wr = 1'b1;
          comp_sel =OC8051_CSS_DC;
          bit_addr = 1'b0;
        end
      OC8051_MOV_RD : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_ORL_R : begin
          src_sel2 = OC8051_ASS_ACC;
          alu_op = OC8051_ALU_OR;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_SUBB_R : begin
          ram_rd_sel =OC8051_RRS_RN;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_XCH_R : begin
          alu_op = OC8051_ALU_XCH;
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_XRL_R : begin
          src_sel2 =OC8051_ASS_ACC;
          alu_op = OC8051_ALU_XOR;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
//op_code [7:1]
      OC8051_ADD_I : begin
          ram_rd_sel = OC8051_RRS_I;
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_ADDC_I : begin
          wr = 1'b1;
          pc_wr =OC8051_PCW_N;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_ANL_I : begin
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_DEC_I : begin
          ram_wr_sel = OC8051_RWS_I;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_INC_I : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOV_I : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOV_ID : begin
          wr = 1'b1;
          psw_set =OC8051_PS_NOT;
          bit_addr = 1'b0;
        end
      OC8051_MOV_AI : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOV_DI : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOV_CI : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOVX_IA : begin
          ram_rd_sel =OC8051_RRS_DC;
          src_sel1 = OC8051_ASS_XRAM;
          wr = 1'b1;
          bit_addr = 1'b0;
          ext_addr_sel = OC8051_EAS_RI;
        end
      OC8051_MOVX_AI :begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_ORL_I : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_SUBB_I : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_XCH_I : begin
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_XCHD :begin
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_XRL_I : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
//op_code [7:0]
      OC8051_ADD_D : begin
          ram_rd_sel =OC8051_RRS_D;
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_ADD_C : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_ADDC_D : begin
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_ADDC_C : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_ANL_D : begin
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_ANL_C : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_ANL_DD : begin
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_ANL_DC : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_ANL_B : begin
          ram_wr_sel =OC8051_RWS_DC;
          wr = 1'b0;
          bit_addr = 1'b1;
        end
      OC8051_ANL_NB : begin
          alu_op = OC8051_ALU_RR;
          wr = 1'b0;
          bit_addr = 1'b1;
        end
          wr = 1'b0;
          bit_addr = 1'b0;
        end
          wr = 1'b0;
          imm_sel =OC8051_IDS_OP2;
          bit_addr = 1'b0;
        end
      OC8051_CLR_A : begin
          wr = 1'b1;
          cy_sel =OC8051_CY_0;
          bit_addr = 1'b0;
        end
      OC8051_CLR_C : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_CLR_B : begin
          wr = 1'b1;
          bit_addr = 1'b1;
        end
      OC8051_CPL_A : begin
          alu_op = OC8051_ALU_NOT;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_CPL_C : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_CPL_B : begin
          wr = 1'b1;
          cy_sel = OC8051_CY_RAM;
          bit_addr = 1'b1;
        end
      OC8051_DA : begin
          alu_op = OC8051_ALU_DA;
          wr = 1'b1;
          cy_sel = OC8051_CY_DC;
          bit_addr = 1'b1;
        end
      OC8051_DEC_A : begin
          wr = 1'b1;
          src_sel3 =OC8051_AS3_DC;
          bit_addr = 1'b0;
        end
      OC8051_DEC_D : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_DIV : begin
          ram_wr_sel = OC8051_RWS_B;
          alu_op = OC8051_ALU_DIV;
          wr = 1'b1;
          psw_set = OC8051_PS_OV;
          bit_addr = 1'b0;
          rom_addr_sel =OC8051_RAS_PC;
        end
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_INC_A : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_INC_D : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_INC_DP : begin
      ram_wr_sel = OC8051_RWS_DPTR;
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_JB : begin
          wr = 1'b0;
          bit_addr = 1'b1;
        end
      OC8051_JBC :begin
          src_sel2 =OC8051_ASS_OP2;
          wr = 1'b0;
          bit_addr = 1'b1;
        end
      OC8051_JC : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_JMP : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_JNB : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_JNC : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_JNZ :begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_JZ : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_LCALL :begin
          src_sel2 = 2'bxx;
          wr = 1'b1;
          pc_sel = OC8051_PIS_I16;
          bit_addr = 1'b0;
        end
      OC8051_LJMP : begin
          src_sel1 = 2'bxx;
          src_sel2 = 2'bxx;
          alu_op = 4'bxxxx;
          imm_sel = 2'bxx;
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_MOV_D : begin
          src_sel2 =OC8051_ASS_DC;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOV_C : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOV_DA : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOV_DD : begin
          ram_wr_sel = OC8051_RWS_D3;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOV_CD : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_MOV_BC : begin
          wr = 1'b0;
          bit_addr = 1'b1;
        end
      OC8051_MOV_CB : begin
          wr = 1'b1;
          bit_addr = 1'b1;
        end
      OC8051_MOV_DP : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
          wr = 1'b0;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_MOVC_PC : begin
          wr = 1'b0;
          pc_sel =OC8051_PIS_DC;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_MOVX_PA : begin
          wr = 1'b1;
          bit_addr = 1'b0;
          ext_addr_sel = OC8051_EAS_DPTR;
        end
      OC8051_MOVX_AP : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_MUL : begin
          alu_op = OC8051_ALU_MUL;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
     OC8051_ORL_D : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_ORL_C : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_ORL_AD : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_ORL_CD : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_ORL_B : begin
          wr = 1'b0;
          bit_addr = 1'b1;
        end
      OC8051_ORL_NB : begin
          alu_op = OC8051_ALU_RL;
          wr = 1'b0;
          bit_addr = 1'b1;
        end
      OC8051_POP : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_PUSH : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_RET : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_RETI : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_RL : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_RLC : begin
          alu_op = OC8051_ALU_RLC;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_RR : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_RRC : begin
          src_sel1 =OC8051_ASS_ACC;
          alu_op = OC8051_ALU_RRC;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_SETB_C : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_SETB_B : begin
          wr = 1'b1;
          bit_addr = 1'b1;
        end
      OC8051_SJMP : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_SUBB_D : begin
          wr = 1'b1;
          bit_addr = 1'b0;
          ext_addr_sel =OC8051_EAS_DC;
        end
      OC8051_SUBB_C : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_SWAP : begin
          wr = 1'b0;
          bit_addr = 1'b0;
        end
      OC8051_XCH_D : begin
          wr = 1'b1;
          imm_sel = 2'bxx;
          bit_addr = 1'b0;
        end
      OC8051_XRL_D : begin
          ram_wr_sel =OC8051_RWS_ACC;
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_XRL_C : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_XRL_AD : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      OC8051_XRL_CD : begin
          wr = 1'b1;
          bit_addr = 1'b0;
        end
      default: begin
          src_sel1 = 2'bxx;
          src_sel2 = 2'bxx;
          imm_sel = 2'bxx;
          wr = 1'b0;
          bit_addr = 1'b0;
       end
    endcase
    end
    endcase
  end
end
// remember current instruction
always @(posedge clk)
  if (state==2'b00)
    op <= #1 op_in;
// in case of instructions that needs more than one clock set state
always @(posedge clk or posedge rst)
begin
  if (rst)
    state <= #1 1'b0;
  else begin
    case (state)
      2'b00: begin
        casex (op_in)
          OC8051_ACALL :state <= #1 2'b01;
          OC8051_AJMP : state <= #1 2'b01;
          OC8051_CJNE_R :state <= #1 2'b11;
          OC8051_CJNE_I :state <= #1 2'b11;
          OC8051_CJNE_D : state <= #1 2'b11;
          OC8051_CJNE_C : state <= #1 2'b11;
          OC8051_LJMP : state <= #1 2'b01;
          OC8051_DJNZ_R :state <= #1 2'b11;
          OC8051_DJNZ_D :state <= #1 2'b11;
          OC8051_LCALL :state <= #1 2'b01;
          OC8051_MOVC_DP :state <= #1 2'b10;
          OC8051_MOVC_PC :state <= #1 2'b10;
          OC8051_RET : state <= #1 2'b11;
          OC8051_RETI : state <= #1 2'b11;
          OC8051_SJMP : state <= #1 2'b10;
          OC8051_JB : state <= #1 2'b10;
          OC8051_JBC : state <= #1 2'b10;
          OC8051_JC : state <= #1 2'b10;
          OC8051_JMP : state <= #1 2'b10;
          OC8051_JNC : state <= #1 2'b10;
          OC8051_JNB : state <= #1 2'b10;
          OC8051_JNZ : state <= #1 2'b10;
          OC8051_JZ : state <= #1 2'b10;
          default: state <= #1 2'b00;
        endcase
      end
      2'b01: state <= #1 2'b00;
      2'b10: state <= #1 2'b01;
      2'b11: state <= #1 2'b10;
    endcase
  end
end
//in case of reti
  if (op==OC8051_RETI) reti <= #1 1'b1;
  else reti <= #1 1'b0;
//in case of writing to external ram
always @(op_in or rst or rd)
begin
  if (rst)
    write_x = 1'b0;
  else if (rd)
  begin
    casex (op_in)
      OC8051_MOVX_AI : write_x = 1'b1;
      OC8051_MOVX_AP : write_x = 1'b1;
      default : write_x = 1'b0;
    endcase
  end else write_x = 1'b0;
end
endmodule
