convert from 16c84 to 16f628a need help
Unfortunately, I'm now tied up until Sunday, so if nobody else has worked out what is going, I will be able to get back to it then.
Jaison - using the working 16F84 PIC you have, can you please give us an a list of what happens from the moment it is turned on.
Then we might be able to work out where in the '628 code it is going wrong.
Good night everyone, Terry turning on the board he is on hold, activating the color (playing to negative) it activates the ptt signal (5 volts) and then releases the beep. If you enter DTMF commands it does other functions.
I'm simulating on Proteus, the 16f84 is ok, the 16f628 is in a loop with the ptt activated and with a beep or CW on and off continuously.
Your second image is not the latest code that Terry posted as it doesn't have the BANKSEL code. It looks like the original 84 code.
Actually, that code needs to be changed to,
ReadEE
        bsf     STATUS,RP0      ;select bank 1
        movwf   EEADR           ;EEADR = w
        bsf     EECON1,RD       ;read EEPROM
        movf    EEDATA,w        ;get EEDATA into w
        bcf     STATUS,RP0      ;select bank 0
        return
I'm guessing that the RP0 code was inserted by Ian and Terry didn't spot it.
Terry with his last file, the program does not report an error but does not turn on the led or beep when I activate the COR. Previous versions up to 3 stay in the loop, 4 and 5 do not loop but do not turn on the leds in the simulator.
Terry, that file still has,
; Read EEPROM byte
; address is supplied in W on call, data is returned in w
ReadEE
    BANKSEL    EEADR
    BANKSEL    PORTA
        return
Which is not going to work because EEDATA is in bank 1.
Edit, I don't like BANKSEL as it always sets both RP0 and RP1 unnecessarily.
I thought I had cleared out the bsf STATUS stuff.
Does the job as long as you don't stick it after BTFSX and your not squeezed tor space - for me it comes from now using the 16F1827 where there's only one bit to change and saves having to look up the datasheet to find out where everything is.
Try this one Jaison.
  • rtp2022_628_5.asm
Bingo Gentlemen, Terry, Pommie and other colleagues for congratulations. Initial test ok, I will try the commands via DTMF to complete the test.
Successfully executed DTMF tests, especially to you Terry and the other colleagues who collaborated with the work, thank you again for all your dedication. May the Great Architect who gave you this intelligence continue to bless you, and may your friends continue to dedicate this intelligence for good, on behalf of all radio amateurs in the southern region of Santa Catarina - Brazil I thank you again and I am available if you need me here . Thanks.
