Capacitive Sensor - 16f628a
cybersky
Hi
I tried to adapt a 3D "touchless" sensor which was based on arduino to pic.
The theory is "simple" set pin to output then set pin low. then set pin as input and wait for pin to go high. i did not use the timer i just used a for loop of 10000 and a count variable. but i think it is not enough "time" (10000) for the pin to go high, I tried using the timer but i am not sure if the interupt is firing or if i have the "bits" set correctly. BUT importantly, are there perhaps any issues relating to timing between setting a pin to an output and then setting it back to an input in oshon?
Please post your full program code.
16f628 using the internal OSC (4mhz)
dim cntchg as word
dim zone1 as word
dim zone2 as word
dim zone3 as word
get3d:
config portb = output
portb = 0 ' all low
'set to input
config portb.4 = input
'get how long it takes to chrg cap
for cntchg = 0 to 10000
if portb.4 = 1 then
       zone1 = cntchg
       goto zone2
endif
cntchg = cntchg + 1
next cntchg
'did not happen in time
zone1 = 0
zone2:
cntchrg = 0
'set to input
config portb.5 = input
if portb.5 = 1 then
       zone2 = cntchrg
       goto zone3
endif
next cntchrg
zone2 = 0
zone3:
cntchrg = 0
'set to input
config portb.6 = input
if portb.5 = 1 then
       zone3 = cntchrg
       goto send3d
endif
next cntchrg
zone3 = 0
send3d:
'used with usb2serial cable - saves on max232.
seroutinv portb.2, 4800, "x", zone1, "y", zone2, "z", "zone3"
waitms 20
goto get3d
end
i retyped it from memory - small enough. i used 2.2k resistor but i was supposed to use 220k. so i am still to change that. but i think i need some waitms's between pin config changes? and a wait after i put the pin low to give "cap" enough time to discharge. but since i only get x0y0z0 i dont think the caps are charging at all.
here is the link i found - so i used the circuit but i wrote my own code based on the theory.
http://www.touchuserinterface.com/2009/03/diy-3d-capacitive-touch-sensing.html
You cannot use the same name/label for a DIM and GOTO label, it gives a Compile error
Dim zone1 as Word and GOTO zone1
I understand that there are newer tech avail. but sometimes its in the "could i do it", know what i mean? and its suppose to be "simple" count.
Hi Eric
Sorry about that syntax error - but like i said i just quickly retyped it inside this reply box. the code is on my home pc.
