c++ convert argv[1] to a char array
main(int argc, char *argv[])
Now, the separators for argv are os dependant but typically they are tabs or spaces so
one, two, and three => four strings
one,two, and three => three strings
If you want number parameters you would convert the string into a number using atoi() atof() ...
HTH
Spiros
Can you explain your question a different way?
It is just that argv[1] is already a char array.
What is it that you wish to do?
Can you give us an example of your problem?
well i wrote this fuction that needs a char array to work but just passing argv[2] doesnt work i wont compile i sayes it cannot convert it
whats the code?
