    Dismiss Notice
btfsc AND btfss
Discussion in 'Microcontrollers' started by emaney, Jun 11, 2007.
  1. emaney
    emaney New Member
    Jun 3, 2007
    9
    0
    can any one tell me differenc between the two, iam realy confused about it for example following code snippet
    lets say is n1=5 and n2=3, wat would be the result if its btfsc/btfss
    NUM1: EQU 0x20
    NUM2: EQU 0x21
    Test: CLRF PortB
    MOVF NUM1, w
    SUBWF NUM2,w
    BTFSS Status, c
    GOTO CASE1
    BTFSS Status, z
    GOTO CASE2
    CASE0: BSF PortB, 0
    GOTO EXTPOINT
    CASE1: BSF PortB, 1
    GOTO EXTPOINT
    CASE2: BSF PortB, 2
    GOTO EXTPOINT
  2. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,235
    641
    Derbyshire, UK
    One is branch if the bit is SET, the other is branch if it's CLEAR - they do the opposite of each other. Along with BSF and BCF they are really the instructions which make the PIC exceptionally useful as a micro-controller - micro-procesors tend not to have bitwise instructions.
  3. emaney
    emaney New Member
    Jun 3, 2007
    9
    0
    please can u explain using the example i stated......especially i dont undersatnd what status in being checked for z.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. donniedj
    donniedj Banned
    Jan 16, 2004
    336
    3
    So Cal
    This is just checking if the difference between two values is 0, negative, or positive. Take a look at the datasheet for the PIC16F628 at microchip.com. Look at the instruction SUBWF. It gives an example of how Carry and Zero flags indicate 0, negative, or positive.
    Code (text):
    Test:
        ; DO AN OPERATION
        CLRF PortB      ;PORTB = 0
        MOVF NUM1, w        ;W = NUM2 - NUM1
        SUBWF NUM2,w
        ; DETERMINE RESULT OF OPERATION
        BTFSS Status, c     ;IF CARRY IS SET,
        GOTO CASE1      ;ELSE- GOTO CASE1
        BTFSS Status, z     ;THEN IF ZERO IS SET
        GOTO CASE2      ;ELSE- GOTO CASE2
        ; SELECT CASE BASED ON RESULT OF OPERATION
        ;   -CASE0 BECAUSE: NUM2 - NUM1 IS 0 (EQUALITY)
        ;   -CASE1 BECAUSE: NUM2 - NUM1 IS NEGATIVE
        ;   -CASE2 BECAUSE: NUM2 - NUM1 IS POSITIVE
    CASE0:  ;--I AM HERE AND ONLY HERE BECAUSE C=1, Z=1
        BSF PortB, 0
        GOTO EXTPOINT       ;GOTO A COMMON PLACE
    CASE1:  ;--I AM HERE AND ONLY HERE BECAUSE C=0, Z="I DO NOT CARE"
        BSF PortB, 1
    CASE2:  ;--I AM HERE AND ONLY HERE BECAUSE C=1, Z=0
        BSF PortB, 2
  6. bananasiong
    bananasiong New Member
    Mar 7, 2006
    1,893
    7
    Malaysia
    Z is the ZERO bit of the STATUS register. If the returned value is zero, this bit will be set.
    btfss STATUS, Z ;if the returned value is zero, Z bit is set so the next instruction is skipped. if the returned value is not zero, just continue executing next instruction.
    It is the other way round for btfsc STATUS, Z.
  7. emaney
    emaney New Member
    Jun 3, 2007
    9
    0
    thank you so much all for fantstic help........thanks
  8. bananasiong
    Mar 7, 2006
    1,893
    7
    Malaysia
    So.. do you understand them finally? :)
  9. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,024
    317
    Brisbane Australia
    The thing to remember when it comes to subtraction is that the carry flag is actually a borrow flag. It is set before the subtraction takes place and if a borrow is required it gets cleared.
    So,
    12-11 = 1 no borrow required. Carry = 1
    11-12 = -1 borrow needed. Carry = 0
    Another way to think about it is that the carry/borrow bit is the 9th bit of the subtraction. The 11-12 then becomes (256+11)-12=255 and bit 9, the borrow bit = 0.
    If your not confused now then your doing well.:D
  10. emaney
    emaney New Member
    Jun 3, 2007
    9
    0
    iam still a beginner in this language but all this has cleared alot of doubt about btfss/btfsc..............
  11. Nigel Goodwin
    Nov 17, 2003
    39,235
    641
    Derbyshire, UK
    Well your question seemed to end up more about status flags than the bit test instructions? :D
  12. Mike - K8LH
    Mike - K8LH Well-Known Member
    Jan 22, 2005
    3,637
    109
    Michigan, USA
    I guess it's all in the way you look at it. After looking at his post I thought immediately about "greater than", "less than", and "equal"...
  13. Pommie
    Mar 18, 2005
    10,024
    317
    Brisbane Australia
    Mike,
    Your posts are becoming more cryptic and less useful.
  14. Mike - K8LH
    Jan 22, 2005
    3,637
    109
    Michigan, USA
    I was just commenting on Nigel's comment (grin).
Share This Page
