    Dismiss Notice
battery temperature sensor
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by abouabdelmajid, Aug 20, 2017.
  1. abouabdelmajid
    abouabdelmajid New Member
    Aug 20, 2017
    10
    0
    Hi everyone.
    Can anybody tell me how to make a battery sensor temperature ? i tought about using LM35 and sticking it on the battery so i can figure out the temperature with arduino but it seem not a practical way for me because i think there must be some way to know the temperature by measuring the curent no ? anyway i am just saying ... can anybody help me how to buld one ?
  2. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,324
    653
    Derbyshire, UK
    The LM35 sounds a reasonable idea - you can't do it without some kind of temperature sensor, and battery packs (such as for a laptop) commonly have them built inside the pack (usually a thermistor).
    Why do you want to know the battery temperature anyway?, it's normally only monitored during charging.
  3. abouabdelmajid
    Aug 20, 2017
    10
    0
    i am trying to do a project about charging a battery by using a solar pannel, it is something not easy to do because there are a lot of things that must be respected to not damage the battery. So i am using arduino and some other electronic devices to control the voltage and curent in a smarty way so i can avoid all what can damage the battery. So one of the things that i should be aware of is the RIGHT TEMPERATURE of the battery itself (not outside or what is around) ALL THE TIME OF CHARGING. if you google the word BTS (Battery Temperature Sensor) you will find that is a smart device that we can put on a one of pole's battery and it gives us the right temperature
    So yes you are right using LM35 seems a helpful way but how can i do it ? do you have any idea ?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Nigel Goodwin
    Nov 17, 2003
    39,324
    653
    Derbyshire, UK
    There are numerous Arduino examples of how to read an LM35 sensor, including those provided with the IDE itself.
    As for the BTS you mentioned, it's appears to simply be a temperature sensor that bolts to the terminal of a lead acid battery.
    What battery are you trying to use?, and how big is the panel - there's no point getting carried away if the panel is too small to ever overcharge the battery.
  6. abouabdelmajid
    Aug 20, 2017
    10
    0
    Actually i am using a 20 watt/17 Volt to charge a 12 Volt 7.2 Ah lead acid battery ... do you think there is no need to worry about the temperature of the battery ?
  7. Nigel Goodwin
    Nov 17, 2003
    39,324
    653
    Derbyshire, UK
    Probably not, and there's probably no need to do anything other than a reverse protection diode, which may even be built in the panel.
    Assuming you've got the battery and panel?, connect them together via an ammeter, and monitor the current to the battery under a range of different conditions.
  8. abouabdelmajid
    Aug 20, 2017
    10
    0
    Ok thank you for answering me
Share This Page
