Misterbenn
Active Member
Hello everyone.
I'm trying to make a universal IR remote for my android smart phone so i can trigger my new DSLR.
I've found IRdroid which seems perfect. It's an active IR transmitter that takes it's input from the 3.5 mm jack of my phone. I've seen some other version just use an IR LED directly connected to the audio output but these all have limited range due to the low power of the audio output.
I’ve attached the circuit diagram. Can anyone tell me why it uses back to back LEDs? My best guess is that the audio output is only good for 20kHz, IR modulation is ~40kHZ, so with this set up you can feed it a square wave and get a pulse on the rising and falling edge effectively doubling your output frequency.
Edit - you can buy the IRdroid but the price is extortionate for what it is. I'm building a through hole version atm and will move onto SMD in the next iteration.
