I am using the following
pic16f84a:
https://www.electro-tech-online.com/custompdfs/2007/04/35007b.pdf
Programmer (icprog):
(JDM Programmer (Ludipipo))
MPLAB IDE v7.51:
This is the tutorial code I am using (that i cant get to work correctly) Tutorial with switch:
The programmer gives me no errors and I have followed the instructions on how to set it up, including activating the xp/2000 driver. The hardware is getting the needed voltage and I am having no probs with it. First I create a new project in Mplab. I follow the setup and select the pic16f84a micro. Once done with the project wizard I then click new which gives me a blank window to write the code on. I copy and paste the code from Mikes Cybot tutorial to the window and then save as a xxx.asm file. I then right click on the source file and add the xxx.asm file. Once done I select build all. It says BUILD SUCCEEDED but it gives several warnings(image added). So when its all said and done all that seems to happen is that the LED blinks in intervals of approx 2secs. The switch is supposed to double the time but does nothing. I have about 1 1/2 years exp in building the circuits and about 1 month with micros. So please go easy on me if I am missing something obvious
pic16f84a:
MPLAB IDE v7.51:
