Aerial Socket
peter5355
Can anyone help Please??????
Bought a double Wall Aerial Socket only one of the females work I am in the UK maybe that is my problem.
Any wireing diagrams would be helpfull
From
Peter
What are you trying to do?, a double wall socket probably requires two feeds for both sockets to work - depends on the exact socket, and what you're wanting to do.
2 feeds
Thank you for your answer
I am trying to get 2 females to work off from one feed so that I do not need a Y connector what you are saying I need to have 2 feeds for each female work
A simple "Y" connector will not impedance match. You need a splitter. Check here:
Note that a two-way splitter will reduce the RF signal by 3Db on each output.
Regards,
Bob
It depends what exact socket you have, the normal one just has inputs for two separate wires, or you can get them with a splitter built-in, or with a diplexer built-in (TV/FM).
The one I bought is this one so I need two feed cables
with two completely separate coax sockets and screw terminals at rear for two separate cables. Overall size 86mm square. Depth from rear of plastic face 15mm.
