Hi , firstly let me say that I am not an electronics expert by any stretch of the imagination but I do have a basic grasp of the subject and have come here as it was recommended as a good place to seek advice .I have an external computer water cooling system known as a Zalman reserator xt and have been heavily modifying it I have now come up against a brick wall though as my knowledge is simply not enough , the problem I need addressing is that the reserator has a built in Aluminium reservoir for the cooling fluid connected to a water pump which I want to want to do away with and replace with 2 pumps each incorporating it's own reservoir, the reserators own reservoir has 2 water level sensors which I believe to be of the Capacitive type each has one single Yellow wire connecting it to the front control /display panel/circuit board which incorporates an alarm should the level fall too low the alarm sounds and the unit shuts down, I want to do away with the level sensors as I do not need them and they would be very difficult if not impossible to incorporate into the modded reserator , my question is can I fool the circuit board into thinking they are present when they are not or could I simply join the 2 single Yellow wires together and achieve my aim that way ? any help or comments would be most appreciated , Gary .
