Adding LTspice subckt
Mosaic
Hello I am having difficulty adding this subckt model.
* Model Generated by MODPEX *
*Copyright(c) Symmetry Design Systems*
* All Rights Reserved *
* UNPUBLISHED LICENSED SOFTWARE *
* Contains Proprietary Information *
* Which is The Property of *
* SYMMETRY OR ITS LICENSORS *
* Modeling services provided by *
* Interface Technologies www.i-t.com *
.SUBCKT 2n6284 1 2 3
* Model generated on Jan 24, 2004
* Model format: SPICE3
* Darlington macro model
* External node designations
* Node 1 -> Collect
* Node 2 -> Base
* Node 3 -> Emitter
Q1 1 2 4 qmodel
Q2 1 4 3 q1model area=10.5246
D1 3 1 dmodel
R1 2 4 8000
R2 4 3 50
* Default values used in dmodel
* EG=1.11 TT=0 BV=infinite
.MODEL dmodel d
+IS=1e-12 RS=10.8089 N=1.00809 XTI=3.00809
+CJO=0 VJ=0.75 M=0.33 FC=0.5
.MODEL qmodel npn
+IS=1.73583e-11 BF=831.056 NF=1.05532 VAF=957.147
+IKF=0.101183 ISE=1.65383e-10 NE=1.59909 BR=2.763
+NR=1.03428 VAR=4.18534 IKR=0.0674174 ISC=1.00007e-13
+NC=2.00765 RB=22.2759 IRB=0.208089 RBM=22.2759
+RE=0.0002 RC=0.001 XTB=2.12676 XTI=1.82449 EG=1.05
+CJE=2.62709e-10 VJE=0.95 MJE=0.23 TF=1e-09
+XTF=1 VTF=10 ITF=0.01 CJC=3.59851e-10
+VJC=0.845279 MJC=0.23 XCJC=0.9 FC=0.5
+TR=1e-07 PTF=0 KF=0 AF=1
.MODEL q1model npn
+XTF=1 VTF=10 ITF=0.01 CJC=0
.ENDS
I have tried the steps to include via spice directive (.inc 2n6284.txt) which does not complain, but when I try to CTRL-rgt click an NPN symbol and paste the '2n6284' name in the 'value' line and then simulate it fails with a 'Can't find definiton' error.
The txt file is in the same folder as the asc circuit. I have successfully added a BAT 54 diode and LM324 opamp model with no probs. See here:
http://www.simonbramble.co.uk/lt_spice/ltspice_lt_spice_tutorial_4.htm
hi mosaic,
Change the .txt to .sub and place the file in the LTS 'sub' folder.
When you ctl right click, change prefix to 'X' as shown on this image
  • Draft111.asc
