a question about PICs
samcheetah
im starting out with PICs so there are alot of questions in my mind about them. plz help me out.
i want to know that if i have an ASM file for a program can i know what size it will occupy in the PIC. i am asking this because i saw a great program written for the '877. i believe that the '877 was used because of its bigger memory space. but i want to know that if that program will fit into a '628 or not.
i know that there could be other reasons why the programmer chose the '877. but anyway this question came into my mind and i thought someone here will give me an answer
I believe if you convert your ASM code to hex, the size of the hex file will be the amount of program memory taken up on the PIC.
wrong! An intel hex file stores the data as ascii and it also contains address information and a checksum, all data that doesn't end up in the pic...
In fact, a 10K hex file ends up as only using 1K5 in the pic
samcheetah, MPLAB allows you to generate a map file on compile (search the help to see how to turn it on). A map file contains memory information such as the amount of mem the prog will use
You can also assemble the code for an 877, then load it into a PIC programmer - WinPicProg (among others) allows you to examine the data as it's going to be blown in the PIC - so you can easily see how big it is.
Quite often the 877 is chosen for it's hardware extras, rather than it's memory size - I always use the larger PIC's, even when memory requirements don't need it - for instance, I always buy the 16F628, rather than the 16F627 - although most projects probably fit in the 627 anyway.
If you assemble the ASM file using MPASM, the resulting LST file wiil give you all the information on program space usage. The ff. is a sample portion of the info:
MEMORY USAGE MAP ('X' = Used,  '-' = Unused)
1000 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
1040 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
1080 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
10C0 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
1E00 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
1E40 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
1E80 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
1EC0 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
1F00 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
1F40 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
1F80 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
1FC0 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
2000 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
2040 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
2080 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
20C0 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
2100 : XXXXXXXXXXXXXXXX XXXXXXXXXXXX---- ---------------- ----------------
2140 : -----XXX-------- ---------------- ---------------- XX-------XX-----
All other memory blocks unused.
Program Memory Bytes Used:  5123
Program Memory Bytes Free: 27645
Because they belong to the same PIC16 family, the '628 will use the same amount of code space as any program written for the '877, assuming you are successful in converting the program from the '877 to the '628.
One advice to allow for easy portability and convertion from one PIC processor to another is to use Microchip's predefined constants by including the correct "INC" file for the processor used. That is, "PIC16F877.INC" for '877s and "PIC16F628.INC" for the '628. The first step to converting is simply changing the include file.
After you build your program in MPLAB you can simply click VIEW/PROGRAM MEMORY. Scroll down to where your last instruction is and read off what memory location it is in.
-Bill
