Could you post the code you have written? It would help us to help you.All my codes are written in ASSEMBLY for PICKIT2.
Faisal said:I need to build a monostable timer inside PIC 16F88 to avoid flickering input from an AC source .
OK i will go on as you say.Hi,
Yes it is possible and would make a good beginners project.
You first want to learn how to control the chips inputs and outputs, so start with the flashing led example from this tutorial.
After that you need a start switch input , an input for the time delay, either analogue or digital and an output for the On time.
