vne147
In your first test you had a 10 ohm resistor to the led so you would have burnt the led out with excess current through it
Agreed.
There are tons on 555 calculators on the web. Here's one:
555 Astable Circuit Calculator
The duty cycle is what you need to pay attention to for varying on time vs off time. A duty cycle of 50% for example has an on time and off time that are equal. A duty cycle of 25% has an off time 3 times the on time.
You can use the calculator to provide some guidance and like SABorn said you can just fiddle around with different components and values until you get the look you want.
Good luck!
