To Recap
I wrote an earlier topic about my microcontroller creating a pulse (3 msec or so) after my actual gate pulse. The gate pulse width was 100usec and the small pulse has a width of 5-10usec.
After connecting a triac MAC15SM, I've noticed that it doesn't behave as I have learned in school. In other words once you gate it, it does not hold until the line commutation. Instead, it fires on an actual gate pulse and on those small width pulses. ( I am also using a MOC3023 M with 560 ohm resistor on pic side and 180 ohm resistor on line to neutral side (MT2) node as specified in MOC datasheet)
So I have two questions:
1. I would like to use a 555 timer in one-shot mode to trigger on the external pulse of width of 100usec. That way I would eliminate the false triggering.
Question: What is the minimum external trigger pulse width that the 555 will detect? I have been all over the datasheet but I could not find this information.
2. I've learned that triacs have a holding current and that once you reach the holding current the triac will remain in conduction mode even if gate pulse is removed. Now, the triac (MAC15SM) seems to conduct only if ONE gate pulse is present during a half cycle. (I also tested two of these triacs using multimeter and when anode and gate are shorted the R=339 ohms and as soon as I remove the lead from gate, R=infinity between MT1 and MT2)
Does anybody have a clue about operation of MAC15SM? Am I reaching the holding current with a 100usec pulse?
Any help will be greatly appreciated as I'm reaching the point of madness.
P.S. I did go through the PIC code several times more, and I can't find anything responsible for this 5-10usec (width varies) pulse. In other words, there is only one triggering per half cycle and that is 100usec long.
