    Dismiss Notice
40-120V DC to 5V@120mA Voltage Regulator.
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by gasson, Oct 21, 2002.
  1. gasson
    gasson New Member
    Oct 21, 2002
    1
    0
    South-Africa
    I urgently require a 40-120V DC input to 5V@120mA Voltage Regulator. Can anybody help me please??
    Urgently required.
  2. mechie
    mechie New Member
    Sep 4, 2002
    591
    3
    Lincolnshire, England
    Problems with high voltages?
    Gasson wrote in a pm ...
    Buck regulator? I assume this is a conventional step-down series regulator?
    This circuit is dropping between 35 and 115 v across the transistors? is it possible that when you switch on one of the transistors sees more (possibly 120v ?) than it can cope with, resulting in destruction of the collector or base-emitter junction? Are the transistors rated high enough to avoid this?
    Or is there a current surge, charging a HUGE capacitor? (slowly increasing the voltage rather than 'banging' on would minimise both these effects).
    The above is guesswork as there is no circuit diagram to look at.
    Would it be possible to have two stages of regulation, the first dropping to maybe 30v. This could ease the stress on power-up.
  3. kinjalgp
    kinjalgp Active Member
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    Use Varistors to protect the Base-Emitter junction from blowing out. Also don't forget to use godd large Heat-Sinks for your power transistors.
    Kinjal
Share This Page
