10 bits adc using 16f877
sixty9sandals
hi..
i have a problem in converting the 10bits analog value into digital and display it in a row of 10 LEDs..what happen is, its just able to display maximum 8bits value, which mean only a value range in 8bits will succesfull been display.
as example: if the value is 760, the displays result suppose to be
10 1111 1000, but what have been display is 00 1111 1000. im using a combination of PORTB, PORTD.0 and PORTD.1:
anyone who can help me,pls?
sixty9sandals said:
hi..
Well, with ADFM set to 1 for the nice, easier ordering, you could copy the value of ADRESL into PORTB, and ADRESH into PORTD, and PORTD should be find because the 6 MSB's that are unused are just 0's, meaning that the 2 bits from the 10-bit A/D conversion would go into PORTD.0 and PORTD.1. Got that? I'm not quite sure though.
You might check my ADC PIC tutorial, it explains it more simply than the datasheet (which can be a bit confusing) - try posting your code, it sounds like you may not be selecting the correct bank for the upper bits?.
hi there..thanks for ur help..ive visit your site..but the problem is all the tutorial are using an assembler. i try to work out using a compiler name MicroCode Studio from pic
so..in the simple way to understand..the code is something like below..
DEFINE ADC_BITS 10
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
MEASURED_VALUE VAR BYTE
REMAINDER0 VAR BYTE
MEASURED0 VAR BYTE
REMAINDER1 VAR BYTE
MEASURED1 VAR BYTE
REMAINDER2 VAR BYTE
MEASURED2 VAR BYTE
REMAINDER3 VAR BYTE
MEASURED3 VAR BYTE
REMAINDER4 VAR BYTE
MEASURED4 VAR BYTE
REMAINDER5 VAR BYTE
MEASURED5 VAR BYTE
REMAINDER6 VAR BYTE
MEASURED6 VAR BYTE
REMAINDER7 VAR BYTE
MEASURED7 VAR BYTE
REMAINDER8 VAR BYTE
MEASURED8 VAR BYTE
REMAINDER9 VAR BYTE
MEASURED9 VAR BYTE
TRISA = 255
TRISB = %00000000
TRISD.0 = %0
TRISD.1 = %0
ADCON1 = 0
ADCIN 0 , MEASURED_VALUE
PORTD.0 = %1
PORTD.1 = %1
PORTB = %11111111
START:
MEASURED_VALUE = 376
REMAINDER0 = MEASURED_VALUE // 2
PORTB.0 = ~REMAINDER0
MEASURED0 = ( MEASURED_VALUE / 2 )
if MEASURED0 < 1 THEN GOTO START
REMAINDER1 = MEASURED0 // 2
PORTB.1 = ~REMAINDER1
MEASURED1 = ( MEASURED0 / 2 )
if MEASURED1 < 1 THEN GOTO START
REMAINDER2 = MEASURED1 // 2
PORTB.2 = ~REMAINDER2
MEASURED2 = ( MEASURED1 / 2 )
if MEASURED2 < 1 THEN GOTO START
REMAINDER3 = MEASURED2 // 2
PORTB.3 = ~REMAINDER3
MEASURED3 = ( MEASURED2 / 2 )
if MEASURED3 < 1 THEN GOTO START
REMAINDER4 = MEASURED3 // 2
PORTB.4 = ~REMAINDER4
MEASURED4 = ( MEASURED3 / 2 )
if MEASURED4 < 1 THEN GOTO START
REMAINDER5 = MEASURED4 // 2
PORTB.5 = ~REMAINDER5
MEASURED5 = ( MEASURED4 / 2 )
if MEASURED5 < 1 THEN GOTO START
REMAINDER6 = MEASURED5 // 2
PORTB.6 = ~REMAINDER6
MEASURED6 = ( MEASURED5 / 2 )
if MEASURED6 < 1 THEN GOTO START
REMAINDER7 = MEASURED6 // 2
PORTB.7 = ~REMAINDER7
MEASURED7 = ( MEASURED6 / 2 )
REMAINDER8 = MEASURED7 // 2
PORTD.0 = ~REMAINDER8
MEASURED8 = ( MEASURED7 / 2 )
REMAINDER9 = MEASURED8 // 2
PORTD.1 = ~REMAINDER9
GOTO START
END
so..any suggestion on solving this problem
sixty9sandals said:
DEFINE ADC_BITS 10
You're trying to store a 10-bit number into a byte and the most significant bits are lost. Try to define MEASURED_VALUE as a 16-bit variable (integer?)
As stated earlier, changed
To
MEASURED_VALUE VAR WORD
and if your just trying to display the binary equiv of a 10-bit register, why cant you just do this?
PORTB.0 = MEASURED_VALUE.0
PORTB.1 = MEASURED_VALUE.1
PORTB.2 = MEASURED_VALUE.2
Goto Start
Instead of this for every bit
