Hello,
I'm trying to learn how the 1-wire works and have been trying to read the ROM from a DS2431, but have not been successful.
When I run the program the serial_number gets all 0xFF, not sure if this is how it's supposed to work.
I'm using RD2 and a 3.8K resistor to VCC on the 1-wire data line.
Any help will be appreciate it.
#define FCY 4000000
#include <p24Fxxxx.h>
#include <libpic30.h>
//.....Configuration bits....//
_CONFIG2(FNOSC_PRI)
_CONFIG1(JTAGEN_OFF & FWDTEN_OFF)
void OW_write_byte (unsigned char write_data);
void OW_write_bit (unsigned char write_bit);
void drive_OW_low (void);
void drive_OW_high (void);
unsigned char OW_read_byte (void);
unsigned char OW_read_bit (void);
unsigned char read_OW (void);
#define READ_COMMAND_DS2431 0x33
#define OW_PIN_DIRECTION LATDbits.LATD2
#define OW_WRITE_PIN TRISDbits.TRISD2
#define OW_READ_PIN PORTDbits.RD2
#define OUTPUT 0
#define LOW 0
#define HIGH 1
#define INPUT 1
#define SET 1
#define CLEAR 0
//....Start Main....//
void main (void)
unsigned char temp;
unsigned char serial_number[8];
OW_write_byte (READ_COMMAND_DS2431);
for(temp = 0; temp<8; temp++)
serial_number[temp] = OW_read_byte(); // Read 64-bit registration (48-bit serial number) number from 1-wire Slave Device
while(1);
//.....End Main.....//
unsigned char loop;
for (loop = 0; loop < 8; loop++)
OW_write_bit(write_data & 0x01); //Sending LS-bit first
write_data >>= 1; // shift the data byte for the next bit to send
if (write_bit)
//writing a bit '1'
drive_OW_low(); // Drive the bus low
//wait(DELAY_6Us); // delay 6 microsecond (us)
__delay_us(6);
drive_OW_high (); // Release the bus
//wait(DELAY_64Us); // delay 64 microsecond (us)
__delay_us(64);
else
//writing a bit '0'
// wait(DELAY_60Us); // delay 60 microsecond (us)
__delay_us(60);
// wait(DELAY_10Us); // delay 10 microsecond for recovery (us)
__delay_us(10);
OW_PIN_DIRECTION = OUTPUT;
OW_WRITE_PIN=LOW;
OW_WRITE_PIN = HIGH;
unsigned char loop, result=0;
result >>= 1; // shift the result to get it ready for the next bit to receive
if (OW_read_bit())
result |= 0x80; // if result is one, then set MS-bit
return result;
unsigned char read_data;
//reading a bit
__delay_us(6);
__delay_us(9);
//wait(DELAY_9Us); // delay 9 microsecond (us)
read_data = read_OW(); //Read the status of OW_PIN
__delay_us(55);
//wait(DELAY_55Us); // delay 55 microsecond (us)
return read_data;
unsigned char read_data=0;
OW_WRITE_PIN = INPUT;
if (HIGH == OW_READ_PIN)
read_data = SET;
else
read_data = CLEAR;
return read_data;
