Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
How much output current do you need? Be aware that the input current needed in a voltage boost circuit is greater than the output current by the same ratio as the voltage conversion.
For example: If you need 100mA out at 12 Volts, the input current needed at 1.5Volts will be at least 800mA. And it'll likely be much more due to inefficiency of the converter. And, if you could get the 555 to run at 1.5V, the circuit you show is very inefficient since you are regulating the output with a zener diode, which is very wasteful of energy.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
