True.
But I was thinking about the "seventh" glow plug all on its own. It would be OK if you had a dummy resistor of the correct value to balance the thing up. But then you have this odd resistor floating about in free air, getting very hot just like a glowplug. JimB
Good point but the dummy plug would only be dissipating 1.5V * 3A = 4.5W which would not be a big deal. The heat could be used to keep the dummy crew comfortable at altitude.
A chassis mount 10W or higher dissipation 500 mili Ohm (0R50) resistor should do the job nicely.
https://www.farnell.com/datasheets/423255.pdf
spec
