Wish to buy Battery, Charger and Buck converter for 12V , 2A router
Flyback
I need to do some Teams interviews and will be in my car in a car park at the time as I will be "on the road".
My Samsung SM-J330FN smartphone will not run Microsoft Teams.
As such I have to use my laptop with my B625-261 mobile router. The router needs a 12V, 2A power supply. As such, I will need to buy...
1...A 24V rechargeable battery pref >2Ah
2...Charger for the above battery (can be uk mains powered)
2....A Buck converter for 18-30V to 12V dc , 2A (to power the router)
Unfortunately I am not allowed to make my own Buck and Charger in the lab where I currently work, as such , I must buy all offtheshelf.
Do you agree the following is the cheapest option...It'll cost £59 total...seems a lot?
24V lithium ion battery and charger £48
Batt and charger
Buck Converter: 18-35v in 12v out at 10A £11
Buck 24V to 12V
B625-261 Router
Router
Why do you need a mobile router?
Your phone apparently has a hotspot/internet sharing feature, so turn it on, connect your computer to your phone's hotspot and you have internet via your cell connection.
Thanks very much, that sounds a great idea.
Of course, i dont have this smartphone on a contract, i just top up its SIM with £10 PAYG whenever i need it. But thats ok....its still worth doing. -And avoids buying all that charger/batt/Buck !!
(i had initially intended to use the router's SIM inside the smartphone to go on Teams (then i wouldnt have needed to pay £10 topup) ...but of course the smartphone doesnt do Teams so thats a moot point anyway)
It turns out that i need to buy the battery and power supply after all...since no smartphone battery would last for a 1 hr teams call with video. Also, smartphones dont have enough uplink/downlink speed for a video teams call...specially if there was more than 2 people on the video call.
Can't you charge the phone from your car battery?
Thanks, but i darent do that, in case the 6 year old car battery is on the way out.
So you are taking a chance on being stranded in your car by a dead battery which supplies at least a hundreds amps to the starter, but you are concerned about the small current a cell-phone charger takes. :rolleyes:
Thanks, it'll be a one hour video based teams call. The router takes 12v, 2A. The laptop will take its bit too.
Just maybe it mightnt be able to give the full needed starter current after that.
Why do you need a 24v battery and buck converter? Seems like you often complicate matters for yourself.
24v batt is common size and most cheap dcdc's are bucks...as such, i need higher volts than 12v, so going for 24v.
24v batt could slip down to 18v whilst discharging, but thats still fine for bucking from 18 to 12v
What gates me is how expensive the "system" is...batt, charger and buck....£59...wow
Oy vey.
How about a 12V, 2A, 6Ah backup supply such as this?
Yes, you can use Microsoft Teams on an Android device. To do so, you'll need to download the Microsoft Teams app from the Google Play Store, install it, and then sign in with your work or school account.
I used it all the time
Your smartphone lacks a mobile power cord? A loaded car battery should have plenty of juice to power your smartphone.
You could use a DROK adjustable buck converter at Amazon. . It has voltage and current limits and will even keep track of how many coulombs of charge you put in. I has a built in diode to prevent back current flow. there is a battery charging function in it.
How did this interview work out?
