wich oscilloscope is better.
STP.Asghari
Hi everyone
I want to buy an oscilloscope. I have two models in mind. One is the FNIRSI 1014D model and the other is the HANTEK-DSO-2C10 model. Which one do you think is better? Is the first model a good model and is it worth buying?
The specifications of these two oscilloscopes are explained in the following links:
It will depend on what kind of work/hobby you do. Audio, motor, radio, or data? Field work or bench work? My field working days are over, so I bought a Siglent SDS1000X-E scope. It has many features for all fields of study/measurement. With FFT and data protocols. And lots of math processing. For a fair price. It exceeds the advertised specs very well too.
I would highly recommend the FeelTech FY6600 for a function generator also. It's quite affordable and also exceeded it's advertised specs too. I use this more than any other instrument. One can draw a waveform, store it and generate it. It comes with hundreds of stored waveforms. It can sweep any parameter of a waveform.
And don't forget an isolation transformer. Allows high voltage signals across motor coils and VFD circuits. If you are in to such things.
