I've a circuit using a hole-through LDR. it works fine but for assembly reasons I've prefer to switch it to a photodiode. There'll be a pull-up resistor and it'll go straight into an ADC which I can control the timing of to give suitability for 10k or 100k impedence. 100k should avoid needing a phototransistor (and avoid the non-linearity).
So in my quest to find a common, reasonably priced, daylight based SMD photodiode I've ran out of luck. Any suggestions?
If I go with using an LED, as long as the LED isn't a paralleled device internally a larger footprint would be more sensitive, correct? Say a 1206 over a 0603.
