When the PIC programming................
chamilackjm
i want to program PIC16F84A with winpic800 software........
when the program this ic they give the two files....
1) C source code complied using HT-Soft PIC C compiler
2) Compiler Hex code file to be directly programmed into the pic
i want to second method for program pic ic...... but i didn't understand program this...
they had been said the specially following one....
Note: Programm the chip with the hex file attached above and remember to set the fuse bits to use "EXTERNAL HS OSCILLATOR" mode!
i can't understand above sentence ......
please anyone help to me to explain step by step how this program to pic16f84a by winpic800 because my first pic program this......
following i attached the two files.....
View attachment c source code.txt
View attachment hex file.txt
1. Open winpic800
2. Connect any programming cable between PC and PIC16F84
3. Open hex file
4. Click on Settings tab
5. Under -Osc- Select HS
6. Click Device Menu -> Program All
1. Open winpic800
3. Open hex file
4 and 5 steps are not seen in my winpic800, what is the problem and i have files that want to program the pic16F877A... it has few files ,, which file that want to program with pic16F877A?
View attachment Alarm_source_code.zip
Then download the most recent version. As you can see in the screenshot, there's a settings tab.
The .hex file. You will also see that there's a settings tab for this one... the fuses/settings are already set as per the source code main file AFAICS.
No worries. Glad you worked it out.
