I think you may want to study electrostatics a little bit to see how charges
diverge naturally. That would help you understand how the charges are set up
in materials like that.
A better idea maybe is to set up the grid of resistors like we talked about in the
other thread. Form a grid of resistors all of the same value, then decrease the
value of each resistor by 1/2 and double the number of resistors (this makes the
grid smaller) and you can also half the length between nodes.
If you keep doing this, you'll eventually have a formula that can tell you about
the resistance between points. It might not be easy to do but you can use
a matrix and look for generalizations as the matrix grows.
You might also look up sheet resistance, and the four point probe method of
measuring sheet resistance.
I guess I really don't understand that model. I'm not sure what the resistors connecting different rows represented.
In the new model that you proposed in this post, I'm not sure how the length between nodes would be changed, what this represents, and what the different values of the resistors represent.
Hi again,
Here's the thing...
If you connect four resistors into a square so that they form four nodes,
you have the beginning of a sheet resistance. It is so far a very crude
model, but still a starting point. The resistance of each resistor
represents a hypothetical incremental resistance along one dimension,
and that's a dimension that has length (or width). Thus, the starting
resistance (say 1 ohm) is the starting incremental resistance and the
length (say 1 inch) is the starting length or width. By calling the lower
left node the origin, we now have a method to not only measure
resistance, but also a method to relate that resistance to actual position
of the four nodes. Thus, resistance becomes a function of position.
Next, we would increase the number of those squares (using more resistors
of course) until we had 4 squares of resistors of squares, except that
all branches are still made from one resistor (not two in parallel).
The other thing we do though, because we are working up to an
infinitely accurate model, is to halve the value of each resistor.
Because we halve the value of each resistor though, we also halve
the length of each resistor. This keeps the same distance between the
four corners of the entire square and so the position still remains relative
to the resistance. The only difference then is that we have now increased
the resolution of the grid, making it more like a sheet.
The next step would again be to double the number of resistors,
halve the resistance and length of each one again, which would increase
the resolution two fold again.
If we keep doing this procedure, eventually we get a really good model
even if we dont use an infinite number of resistors. The resistance
between two points would be related to the position of those points,
and a formula can be developed.
This could be interesting to do even if you dont ever use it.
BTW, what is your goal with this?
Four resistors:
o R o
R R
o R o
o R o R o
R R R
o R o R o
R R R
o R o R o
Hi again,
The reason i went back to the resistor model (which by the way is not a crude
model but the foundation for a very accurate model) is because i felt that that
would fit the bill better than looking at an electrostatic field. It might be good
to look at that anyway, but the thing is that the resistive sheet is a finite object,
whereas the electric field is not confined to a closed space like that. Thus,
we need something that will keep all the currents confined like the resistive
sheet would (assuming you are still interested in resistive sheet characteristics).
Let me see if i can draw this quickly...
Code:Four resistors: o R o R R o R o
Add more resistors and halve their resistance and the
distance between nodes:
Code:o R o R o R R R o R o R o R R R o R o R o
Each resistor value above is one half of what it was
previously.
o R o R o
R R1 R
o R o R o
R R2 R
o R o R o
Hi again,
Lets start with this:
o---R---o
That's one resistor between two nodes, not sheets.
This is a very simple resistor.
With this all we know is the voltage applied between the two ends, and
the current that flows. Thus, we know the voltage at a distance d=0
and at a distance d=1, and the current of course, but that's it.
Now we expand:
o-R-o-R-o
Now both R values are made to be 1/2 of what they were before.
Now we have the same for the two ends, and that the distance at
the left end is zero and at the right end is 1 just like before, but now
we have a better model because we now can calculate the center
value of voltage, which is 1/2 of what it is on the right (1/2 in this case).
Thus, we have doubled the resolution of the one dimensional model.
Now we expand again:
o-R-o-R-o-R-o-R-o
with the exception here that this string of resistors would have the same
total distance equal to 1 (it cant be drawn any smaller in pure text).
So lets imagine that we are now zoomed by a factor of 2 also.
What we have now is a better model, because we now know the voltages
of both ends and in the center (as before) but also at a distance of 0.25
and at 0.75 (say inches for simplicity).
If we repeat this process of expanding we end up with a model that can
tell us the voltage at any distance from the left end. The resistance at
that point would be that voltage divided by the current. Or in terms of
distance, with an applied 1v and an initial distance of 1 inch we would have
resistance equals distance divided by the total current.
Each resistor would have a value that we can call the incremental resistance.
