What can be the reason behind this tragedy?
ahsrabrifat
Active Member
In my country, a mother died along with her daughter, whom she was holding in her arms while cooking rice in a rice cooker. She plugged it in and got electrocuted. What can be the reason behind this electrocution? Where might the fault be?
You're Bangladesh?
You can start with lax inforcement of people stealing power with illegal splices into the grid. If the taps into the grid are not authorized, there is likely no inspection, no circuit breakers, no grounding, no GFCI, ...
It's sad but you get what you enforce (or what you don't enforce).
Good old USA has done Bangladesh like things in the past. Like the
"all American 5" tube radios with hot chassis. Dont be station selecting
or changing volume while taking a bath.....
If its stupid we done it here, and rinse and repeat in many instances.
Like industrial pollution. Been doing that in my small town, had to raise
$5M to filter water supply from known cancer causing chemicals. And
progenitor who did that got kicked out of another State and we welcomed
them in knowing that.
Stupid is as stupid does.....
Unfortunately, many safety regulations are only legislated after an accident has already happened.
Hopefully this tragedy will prompt legislators into action. That would be the redeeming quality for the accident.
Also I assume continued using the British style of power bestowed on it. from days of the Raj.!power system?
230v powered outlets?
Are those outlets 230V to ground/neutral?
Would be much safer if it were a split-phase 230V with 115V to ground.
The Beitish system is safe if used correctly.
It is one wye phase of a 3phase transformer with the star point neutral grounded.
The UK system is probably the safest in the world, as we have better infrastructure and higher standards - for example not allowing mains sockets (other than isolated shaver sockets) in bathrooms - so we don't get electrical bathroom accidents like countries with lower standards. As far as I'm aware the death rate by electrocution in the USA is no lower than that in Europe/UK.
230V isn't particularly dangerous, you have to work hard to get killed by it - however, Bangladesh might use a higher voltage, but doesn't use the UK system.
Incidentally, the UK uses 240V mains, not 230V - the 230V specification is for European appliances, in order to mean they work in either the UK (240V) or Mainland Europe (220V).
A quick google finds mentions of alarming death increases in Bangladesh, unsurprising when you see pictures.
When I practiced in the UK from the 1950's it was 230v and gradually introduced 240v as standard.
I have been away from it for some decades.
(I/we used imperial wire size at that time e.g. 3/.029 etc)
That's before my time, but I don't remember ever hearing of the UK being 230V? - but certainly in the 1950's it wasn't standardised across the UK. So it could easily have been 230V where you were, and different in other places - even the frequency wasn't standardised, including some areas having DC mains, again of varying voltages.
This was why TV's and Radios were mostly AC/DC (good name for a band:D ) and had (wide ranging) selectable mains taps to set the voltage for where you actually installed it. It was probably the 70's before 240V 50Hz was pretty well universal?.
That jogs a memory, I remember working at Oxford Observatory, used 100v? DC , we converted it to AC in order to hook up to the grid!
Back then I was an Electrician, moved on since then!
A small local town not far from me had DC mains, it's called Staveley, and it was because the local Company (Staveley Works) built their own power station, and used it to power the town as well - I presume the reason for the towns existence was the works?.
The works are long gone now, but you can see the extent of it here:
No sir. The accident took place only 2 days ago. I don't know if any investigation is going on. :(
Looking at the pictures of the infrastructure it seems unlikely they would investigate anything?, what would an investigation achieve? - the high numbers of deaths are widely reported all across the internet.
