What are operational transconductance amplifiers (ota)?
Syafiq
I am designing a Switch Capacitor Filter and have to cascade it with the OTA for some reason. Can't seem to find an easy explanation on what is an OTA. Can anyone kindly explain the function and operation of the OTA? Thanks! I am relatively new to this field.
Really? What is so complex about the very first sentence from Wikipedia?
"The operational transconductance amplifier (OTA) is an amplifier whose differential input voltage produces an output current."
Maybe he is having trouble understanding what a differential input is?
A differential input is a set of inputs that detect the difference between the two inputs and generate a signal based on that difference rather than on the absolute level of some single signal. So it gets two signals then subtracts them, and uses the result of that subtraction to generate an output.
The types of inputs can be either voltage or current, and the type of output can also be either voltage or current. It depends on the amplifier design.
With an OTA however, the inputs are voltages and the output is current. That and the differential input means that it will measure two voltages, subtract them, then amplify that difference and output it as a current level. The internal gain of these amplifiers can be high but we can also adjust it with the additional terminal.
For example, say we have an OTA with internal gain of 10, and on the input inverting terminal Vn we have a DC voltage level (measured from ground) of 2.000 volts, and on the non inverting terminal Vp we have a voltage level of 2.001 volts. Internally the OTA will subtract the two Vp-Vn and so it will do 2.001-2.000 and end up with 0.001 volts, then amplitify that by the internal gain of 10: 0.001*10 to get 0.010 volts but then will output that as a current 0.010 amps. Or we can look at it as 2.001-2.000=0.001 and then change that into a current, 0.001 amps, then amplify that to get 0.010 amps at the output.
That's the basic behavioral operation, but we also see an additional terminal on the real life devices that allows us to change the gain. This leads to some novel applications. In the above example this means we could vary the gain from say 10 to 5, so instead of getting 10ma output we would have gotten 5ma output.
The term "transconductance" itself simply means taking a voltage as input and turning it into a current, usually with some gain. The gain is usually indicated as "gm". So in the above example we had a "gm" of 10.
Thanks a lot! Helps me understand better!
I have a schematic of the OTA here, but I do not understand the way it functions. Can it be explained in an analogous way with a standard amplifier?
Also, normal op-amps are used to drive resistive loads while an OTA drives a capacitive load. What are the differences between them? Does OTA drive capacitive loads as its output is current? Thanks!
transconductance amps are often used to drive signals down long bits of cable (twisted pairs etc). Currents are more immune to noise spikes than voltages and as the previous poster said, tend to be better at driving highly capacitive loads
an OTA is basically a simplified op-amp
an op-amp has 3 stages: differential input, transconductance (gain) stage, and output stage.
an OTA just has the differential input and transconductance stages (and no output stage)
OTA is probly not something you use much in practice, it's more a way to introduce op-amps in classrooms
sort of like the way they teach you half-wave rectifiers (not used in practice) before they teach you full-wave rectifiers (used in practice)
