What am I missing on the initialization of PIC16F877?
kyru27
I'm trying to control a pulse counter with a PIC and I'm having problems with the initialization, the code is:
BANKSEL ADCON1
MOVLW 0x0F
MOVWF ADCON1
MOVLW 0x10
MOVWF TRISA
MOVLW 0x00
MOVWF TRISB
BANKSEL PORTA
MOVLW 0x3F
MOVWF PORTB
But whatever I put on PORTB (wich is intended to send a "0" to a digit display) I always get a 0xFF, (so a 8 into display) in fact, all pins of the PIC are on High level. I guess I must be forgetting something as the Pic doesn't seem to be broken, I can read and program it without any issue, so the problema hast to be another one.
Can someone please help me with this? I'd be really grateful.
Thanks.
I've resitors, they are at each exit of the PORTB and they illuminate all the displaay segments, it's a common cathode display.
I'm bringing 5 V to its corresponding pins , GND to their corresponding pins and so I guess it has to be the code, I guess just with VDD and GND set I should be measuring a 0x3F at PORTB wit a multimeter wheter I have resistors or display.
Thanks.
Same code works on simulation...
I don't know if you assembled with MPASM but here's what I did
	list p= 16f877
	#include "p16f877.inc"
loop	equ	20h
	org 	0
	goto	init
init
	BANKSEL ADCON1
	MOVLW 	0x0F
	MOVWF 	ADCON1
	MOVLW 	0x10
	MOVWF 	TRISA
	MOVLW 	0x00
	MOVWF 	TRISB
	BANKSEL PORTA
	MOVLW	0x3F
	MOVWF	loop
	MOVF	loop,W
	MOVWF 	PORTB
	DECFSZ	loop,F
	goto	$ - 3
END
Guess I'll give it a try, I don't think a loop should be necessary to initialize the PIC, but if it works that way...
Thanks.
Yes. 5 Volts all the time being sent there... Guess I'll try to redo the circuit from the beginning if someone can tell me that nothing more is neccesary to configure properly the ports.
