Probably uses a bridge configuration to get the extra power. You can't parallel amps.The quality (i.e., measures like THD) will be the same whether the chip is doing 2x60W or 1x120W, as I believe it simply runs both amplifiers in parallel to make 1x120W.
Actually you can, but it will certainly be a bridge configuration.Probably uses a bridge configuration to get the extra power. You can't parallel amps.
The difference is mainly in the impedance of the speakers, but also two 12 inch speakers will tend to be louder, and sound better, than a single one (assuming similar specs).It doesn't make any difference does it?
Just looked it up in wikipedia, didnt realize that. Though the configurations are similar. Either way it's the same two amps sharing the load.Probably uses a bridge configuration to get the extra power. You can't parallel amps.
Because it's not true - you CAN parallel amps, if you do it properly, and it's relatively common - again it's down to speaker impedances. In all three configurations the output power is identical.Just looked it up in wikipedia, didnt realize that. Though the configurations are similar. Either way it's the same two amps sharing the load.
At least I learned about the bridged configuration, which makes more sense to me anyway. Seems like it would eliminate the problems with paralleling amps, such as matching. How do you get around that problem? because it seems like its bound to fail eventually if the only way to get around it is "ensure good matching"Because it's not true - you CAN parallel amps, if you do it properly, and it's relatively common - again it's down to speaker impedances. In all three configurations the output power is identical.
You use identical amps, and design it correctly, the gain-clone IC's are specifically designed to be used in that way - like I said, it's ALL to do with speaker impedances:At least I learned about the bridged configuration, which makes more sense to me anyway. Seems like it would eliminate the problems with paralleling amps, such as matching. How do you get around that problem? because it seems like its bound to fail eventually if the only way to get around it is "ensure good matching"
No it isn't. In parallel (if it was possible) both amp outputs would drive exactly the same voltage swing across the speaker load and thus deliver half the current. However, since the outputs are not exactly alike, they would fight with each other and be sourcing or sinking current from one output to the other amp's output. That's why you can't simply strap two amp's outputs in parallel to try to drive lower impedance speakers.Just looked it up in wikipedia, didnt realize that. Though the configurations are similar. Either way it's the same two amps sharing the load.
That's news to me, but I've only been doing it for 40 years. If amps are designed to run in parallel, they would have to contain some internal circuitry specifically to make one amp the "master" and the other the "servant" so that they don't try to force slightly different voltages at the load. They don't have exactly the same gain, so they would be trying to establish differet voltages as set by their own feedback.Because it's not true - you CAN parallel amps, if you do it properly, and it's relatively common -
If you mean for a specific speaker impedance, that is not correct. Bridge amps are used specifically to increase output power for a given impedance by increasing the voltage swing at the load. A single stereo amp used in a car (14V rail) is biased to center line (7V) and swings about 5V up and down from 7V. That means the speaker sees a signal voltage swing of 10V (p-p) which is AC coupled to the speaker whose other terminal is grounded. In a bridge with the same 14V rail, the speaker terminals "float" and one side goes up and the other goes down. It can swing about 12V each way, so that makes 24V (p-p) possible voltage excursion creating much more power for the same speaker impedance which is P = V(sq)/R where R is the speaker impedance.again it's down to speaker impedances. In all three configurations the output power is identical.
You have to have one of the amps voltage control loop being the master and the other amp having it's voltage loop disabled so it will act like a current source whose current is dictated by the master amp.How do you get around that problem? because it seems like its bound to fail eventually if the only way to get around it is "ensure good matching"
I'm going to run some simple numbers here...If you mean for a specific speaker impedance, that is not correct. Bridge amps are used specifically to increase output power for a given impedance by increasing the voltage swing at the load. A single stereo amp used in a car (14V rail) is biased to center line (7V) and swings about 5V up and down from 7V. That means the speaker sees a signal voltage swing of 10V (p-p) which is AC coupled to the speaker whose other terminal is grounded. In a bridge with the same 14V rail, the speaker terminals "float" and one side goes up and the other goes down. It can swing about 12V each way, so that makes 24V (p-p) possible voltage excursion creating much more power for the same speaker impedance which is P = V(sq)/R where R is the speaker impedance.
This is wrong, actually backwards:I'm going to run some simple numbers here...
assume your amplifier is designed for a 10Vpp swing:
Single Amp: 10Vpp into 8Ω = 1.25App --> 1.25A*10V = 12.5W = 20V^2/8Ω
Bridge Amp: 20Vpp into 8Ω = 2.50App --> 2.50A*20V = 50.0W = 20V^2/8Ω
Parallel Amp: (each amp "sees" half the load of an 8Ω speaker):10Vpp into 4Ω = 2.5App --> 2.5A*10V = 25W = 10^2/4Ω
(This assumes the amps are perfectly matched, just for sake of calculation)
So a parallel amp will double the power of a single amp, whereas bridge configuration power goes as V^2.
However if your amps are limited in current drive to, say, 1.25A, the only way is to parallel them...
That is something that is not intuitive... that although you have two amplifiers one configuration has more power than the other.
The power of the chip the OP posted about is doubled when run in mono mode, which speaks of paralleling to me!
If you parallel the outputs of two amplifiers, each one supplies half the current and sees TWICE the effective load impedance. same voltage swing, half the current, effectively sees twice the impedance. The same voltage swing across the speakers, same power delivered to the speakers, but the current is divided between the two outputs. No power gain at all.Parallel Amp: (each amp "sees" half the load of an 8Ω speaker):10Vpp into 4Ω = 2.5App --> 2.5A*10V = 25W = 10^2/4Ω
Unless you lower the speaker impedance somehow, paralleling outputs can NEVER increase power to the load. Impossible.The power of the chip the OP posted about is doubled when run in mono mode, which speaks of paralleling to me!
