voltage to current converter
dardar86
I need to create a circuit to convert 0-10 V to 4-20ma, using a 741 op amp.
I need to use this op amp because I already have it and a power supply.
If anybody could show me a circuit using a 741 op amp to achieve the above I would be greatly appreciative!!
Regards,
DarDar86
Here you go, you'll need a band gap reference for the -1.2V, see the LM113.
Or course, you could recalculate the resistor values to suit a different voltage and trim it.
hi hero,
As the Vout of the OPA is always > +0.5V the -15V supply is not required, it would reduce the circuit cost.
I thought the input is supposed to be able to go down to 0V?
It's a 741 which needs a dual supply and a negative voltage is already required to get -1.2V
No doubt there's another way of doing this with a single supply amplifier so no negative supply is required.
hi hero,
Look at this variant of your posted circuit.
  • V2Cconv2..asc
hi hero,
The problem with that is the current will vary between 0 to 20mA as the voltage is varied between 0 to 10V.
The original poster wanted 0 to 10V to be converted to 4mA to 20mA, hence the negative voltage to get 4mA when the input voltage is 0V.
It's important that the current never drops to zero because that's treated as an error on a current loop transmission system.
https://en.wikipedia.org/wiki/Current_loop#Process-control_use
Thats a small change to make the circuit 4mA to 20mA.
Thanks for the link, but I have used 4-20mA for quite a time.;)
  • V2Cconv3...asc
That's a better way of doing it.
You'll need a regulated 15V supply to power the circuit, I know you know this, it's for the original posters benefit.
