Voltage stepper
wickedfun
Hi all,
I am in need of help with a circuit I would like to build. I can build an electronic circuit no problems but design them I cant. What I am wanting to do is have a single push button switch that will have 4 different stages. I have a 12v battery, on the first push of the button I want to ramp up from 0 to 8vdc (+/- 2 second ramp time) , the second push of the button I would like to ramp from 8vdc to 10vdc (also a 2 second ramp) the third push will ramp from 10vdc to 12vdc (also 2 second ramp) on the forth push of the button I would like to switch the circuit off and reset. Should I push the button again I want to start all over.
If anyone could give me some advice as to where I can start searching for help on this and what I should search for.
Thanks in advance
Sean
wickedfun said:
Hi all,
Thanks in advance
Sean
Can you explain why you want this? Are you going to drive some sort of load (motor, lamp, etc.) with it?
What I suggest is this:-
Find an adjustable voltage regulator that has a reference / feedback voltage to ground. These are usually 1.25 V to ground. LP2952 is one type.
There are normally 2 resistors connected to the feedback point. One is to ground and one is to the output voltage. You need to have a third resistor connected between the feedback point and a control signal.
The control signal would come from an output pin microcontroller. The microcontroller output will have a variable duty cycle, to control the voltage. There has to be a capacitor to smooth the duty cycle and make it a variable voltage.
The pushbutton would go to a microcontroller input.
You need R1, R2 = 10 k:ohm:
R3 = 7.7 k:ohm:
R4 = 48k:ohm:
if you are using a voltage regulator with a 1.25V feedback.
R5 can be just about anything.
C1 should be about 100 :mu:F
The pic program needs to remember what part of the cycle you are in, and it needs to produce a variable mark-space ratio. The bigger the mark-space ratio, the smaller the output voltage, but this circuit has the advantage that there is a linear relationship between mark-space ratio and voltage.
Then use a PWM circuit to control the brightness rather than messing around with trying to vary the voltage.
