voltage drop
blessbernie
after putting my PIC in d socket, d voltage from the 7805 drops to abt 1.4v. wat could be the cause. urgent plz. it's jst a simple temperature sensor circuit
Something is drawing more current than the supply can deliver.
Carefully examine your circuit to see if there are any stray wire strands or solder splashes causing a short-circuit somewhere.
Double-check the circuit you have built, to ensure it's consistent with the schematic.
Or the 7805 could be misbehaving- perhaps oscillating. Have you got any decoupling capacitors across the supply lines. If not try 100nF.
spec
I would strongly suspect you've put the chip in the wrong way round! :D
This would produce exactly what you're getting - the chip will also be getting red hot, so don't touch it.
