Variable timer interrupts with 16F88
Homerzinho
Hi guys, my PIC is connected to a buzzer, and I want to make my code in way that when I press a button the frequency of the buzzer changes.
To change that frequency, I *MUST* use interrupts.
I use cc5x compiler.
I was thinking of something like:
void interrupt isr() {
    static volatile bit saved_dtr;
    saved_dtr = dtr;
                   ;                                        // save the current status of dtr
                ;                                           // disable reception of serial chars
    dtr = B_HIGH;
 if(TMR1IF) {
            ++tmr_aux;
            TMR1IF = false;
       PORTB.1=~PORTB.1;
        dtr = saved_dtr;
                       ;                                  // restore the status of dtr
I´m at school now and I can´t test the code.
I need some directions on how to make interrupts with variable timers, and some documentation on TIMERS in the cc5x compiler.
Thanks in advance, I really need to understand that.
My finished code looks like this now
void interrupt isr(void)
  if ( T0IF) /* TMR0 overflow interrupt */
            CLK3=~CLK3; //The buzzer port
            TMR0 = 0; // For reseting Timmer 0 value
            T0IF = 0; /* reset Timmer 0 flag INTCON<2>*/
main()
T0CON = 0b.1100.0100;
TMR0 = 0; /* 256 @ 64 = 1.64ms/2 delay */
INTCON = 0xF0; // Enable interupt
/*the function I call if the button is pressed (Every time the button is pressed, the frequency should increase to a maximum then return to the first value)*/
void muda_p(void)
switch(T0CON)
case 0b.1100.0111: T0CON=0b.1100.0100; break;
case 0b.1100.0110: T0CON=0b.1100.0111; break;
case 0b.1100.0101: T0CON=0b.1100.0110; break;
case 0b.1100.0100: T0CON=0b.1100.0101; break;
Now, I´m trying to do that:
            CLK3=~CLK3;
T0CON = 0xC5;
Will that work in cc5x? I can compile right now because I´m at linux.
My plan is to change T0CON everytime the button is pressed.
Will that work?
You would be better doing something like,
        CLK3=~CLK3;
        TMR0 = PreSet;   // For reseting Timmer 0 value
Then changing the value of Preset will alter the frequency. However, Timer0 is very inflexible, timer2 is much more useful for this and you can just change the value of PR2.
BTW, there is no register called T0CON.
I used that code
interrupt int_server( void)
    int_save_registers    // W, STATUS (and PCLATH)
    if (T0IF)  {
        TMR0 = -45;
        if (CLK3 == 1)
            CLK3 = 0;
        else
           CLK3 = 1;
        T0IF = 0;  /* reset flag */
    int_restore_registers // W, STATUS (and PCLATH)
And when I change the freq i use
switch(TMR0)
case -200: TMR0=-100; break;
case -100: TMR0=-50; break;
case -50: TMR0=-25; break;
case -25: TMR0=-200; break;
But now the buzzer is oscillating in a high frequency and the rest of the code pratically do not execute.
I will try to rise up these values.
If that doesn´t work, what can I do to make the frequency of interruption change in real time?
You need to set the prescaler to something sensible - see the OPTION register for details. You then need to put a value in a variable as I posted earlier.
Oh, I see.
I used OPTION =2 now, and Iḿ using TMR2
OPTION = 2;
TMR2 = 0;
TMR2IE = 1;
GIE = 1;
and changing PR2 as follows
void muda_p(void)
switch(PR2)
case 200: PR2=100; break;
case 100: PR2=50; break;
case 50:  PR2=25; break;
case 25:  PR2=200; break;
Do you think it will work?
Man, thank you very very much for helping me out.
With PR2 = 200, it should buzz at ~5kHz
You need to setup T2CON. If you set it to 0x05 it will make PR2=200 give a frequency of 1250Hz which should be a nicer sound. You also need to set PEIE or your interrupts won't work.
