Vacuum Tube Breadboard Adapters
ZeusMC
Anything like this, available in UK?
Don't worry :) As a newbie I'm only going to be following along, low DC voltage.
Cheers.
Tubes need BIG parts 400v & 600v capacitors, and BIG resistors, & a big power transformer and 2 audio transformers & a choke, & big filter caps. etc. YOU going to need a much BIGGER breadboard for all those big parts. How you going to build a Dynaco 70 amplifier on that tiny breadboard?
Digikey sells tube sockets from a place called Tube Depot. They have a variety of styles, including with pc pins.
It wouldn't be difficult to lay out circuit boards in the style of those shown to create your own adapters. A minor problem is that drawing of the PCB footprints aren't available, so you're have to get the sockets and make measurements to lay out a circuit board.
Tube Sockets & Adapters | TubeDepot.com
Missed your reply, just read it. Thanks.
Generally for tube stuff, you use fahnstock clips. See https://antiqueradio.org/transmitter.htm
Never heard of them :D
But back in the valve days you simply built things - and a breadboard was something you sliced your bread on, and if you used it for electronics (which is where the name comes from) you knocked nails in it and soldered to them.
But the entire scheme seems flawed anyway - he's talking about running at low voltages, and valves generally don't work properly at low voltages.
I had a quick look at that but couldn't see any mention of it. I then looked on Wikipedia, https://en.wikipedia.org/wiki/Fahnestock_clip Don't see how that could connect a tube into a breadboard.
See: https://electronics.stackexchange.com/questions/48516/why-are-they-called-breadboards
Anyway, the idea is that you could attach a socket to a piece of perfboard and put those Fahnstock clips around it. Elevate the socket wit some standoffs and have at it.
I don't like the tube to DIP docket to breadboard idea at all. To screw terminal strips - yes. To those component strips that the old TV's were made from - yes.
