Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
The circuit at Electronics-Lab is an Instructable with some errors:
1) It doesn't have a peak detector circuit at its input so the LEDs will be a dim blur.
2) It uses two 1.2k resistors but doesn't show where the second one goes. Does it replace the 7.5k resistor on the datasheet? Then the LEDs will be dim and the signal must be 2.5V peak which is too high.
I hadn't seen that one. The few project I found with Google has a transistor to handle input. However I don't have a convenient transistor cross reference, and BC series transistor isn't exactly readily found locally. Could I get away using 2n3904 or 2n3906 instead of BC series?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
