User defined characters-alfanumeric LCD
ady689
Haw I write a rutine in MPASM to generate user defined charcters on a alfanumeric LCD, i find a similary example but is write in C++ and i dont undersant..nothing....Can you help me?
I read this tutorial, and he is not what i want
Purpose: - Load a user-defined character definition into the HD44780 character generator memory.
Quick explanation on how to implement user-defined characters:
First you will need to make a pixel definition for the characters
you want to use. Below is the pixel definition for an underlined
'0' (char code 0x30) based on a 5x7 dots character definition:
| bits | byte
row | 76543210 | value
000 | xxx | 0x0E
001 | x x | 0x11
010 | x xx | 0x13
011 | x x x | 0x15
100 | xx x | 0x19
101 | x x | 0x11
110 | xxx | 0x0E
111 | xxxxx | 0x1F
I think the datasheet states clear enough.
Set DDRAM address, CGRAM address and followed by CGRAM data.
ady689 said:
i dont understand very good, practicaly can you give me an concrete example?
Attached is a Oshonsoft Basic program and its asm listing output.
You should be able to figure out how defined characters are created and used.
Hope this helps.
EDITED: its best to download the *.asm to view off line, else there is no formatting!
It goes like this,
MOVLW B'01000000' ;USER GRAPHIC 0
CALL COMMAND ;SENT TO LCD AS COMMAND
MOVLW B'00000000' ;PIXEL DATA 1 OF 7
CALL DISPLAY ;SENT TO LCD AS DATA
Then to actualy print the user graphic
MOVLW .0 ;USER GRAPHIC POINTER
