USB Mains Charger - schottky equivalent?
gregmcc
I've got a USB mains (100-240VAC) travel charger (Model ST-099A20) that has stopped working.
I've opened it up and traced it down to a faulty shottky diode. Or at least I think it's a schottky diode from the info I can find.
Its the 2 black SMD diodes by the white paste in the pic. I've removed them and one of them is shorted.
On the diode is
JF
SS36
From the info I can find here:
https://www.electro-tech-online.com/custompdfs/2013/01/88751.pdf
Its Maximum repetitive peak reverse voltage = 60V
Maximum RMS voltage = 42V
Maximum DC blocking voltage = 60V
Maximum average forward rectified current = 3A
Peak forward surge current 8.3 ms single half sine-wave superimposed on rated load = 100A
I've checked out the local electronics shop and cant find the same smd device.
My question is can I use something like a 1N5822 in its place?
Max. Recurring Peak Reverse Voltage: 40V
Max. RMS Voltage: 28V
Max. DC Blocking Voltage: 40V
Max. Average Forward Rectified Current at 95°C: 3A
Max. Instantaneous Forward Voltage at 3A DC: 0.525V
Max. Forward Voltage at 9.4A: 0.95V
Max. Average Reverse Current at 40V DC: 2mA
If this is not suitable, can someone please recommend something I could use. It doesnt have to be a SMD.
What is the ouput current rating of that charger?
I would guess the 3A rating of the 1N5822 makes it a suitable candidate (even if the voltage rating isn't as high as the original).
Great - thanks. I'll try that and see how it goes.
Update: 1N5822 works like a bomb. As good as new :)
