USB adapter/cable ???
MikeMl
Most Helpful Member
How do I get from a Nextbook NXW9QC132 Tablet PC's MicroB USB 2.0 port to a standard size USB B (like is on a Printer)?
The device is not a printer; it takes its power from the tablet (it is actually an SDReceiver).
Do not want to, or need to, ever charge the tablet from its USB port (it has a separate charge connector).
Hy Mike,
If I have got your question right, there are adapters and adapter cables for converting from micro to standard USB- just Google. I have used them and they work OK.
spec
There is more to it....
This **broken link removed** holds the key to what I didn't know...
Read the part about what pin 4 in the micro B end does...
Does the suggested lead not work?.
The suggested lead might work if it includes the magic phrase "OTG" or "On-the-Go" in it's on-line description.
Unfortunately, there are three distinct versions of the lead suggested by Spec.
1. no connection to pin 4. (pin 4 floating)
2. pin 4 grounded to pin 5. (the one that works for me)
3. pin 4 connected to pin5 through a resistor. (I haven't tried that one).
I need the tablet to recognize that my SDR receiver was plugged in. If I use version 1 if the cable (above), the tablet does nothing when the cable is inserted.
