Jules_Theone
I'm using the 16F688 pic, I've got it to flash an led on and off, wait for a button to be pressed before running some code, but I haven't been able to get it to talk to my PC yet. My code is attached, can anyone see anything obviously wrong with it - it's probably something simple I'm forgetting. Also I'm using the PicKit1 kit with the serial part populated with a max 232 etc, if that helps.
; This file is a basic code template for object module code *
; generation on the PICmicro PIC16F688. This file contains the *
; basic code building blocks to build upon. As a project minimum *
; the 16F688.lkr file will also be required for this file to *
; correctly build. The .lkr files are located in the MPLAB *
; directory. *
; If interrupts are not used all code presented between the *
; code section "INT_VECTOR and code section "MAIN" can be removed. *
; In addition the variable assignments for 'w_temp' and *
; 'status_temp' can be removed. *
; If interrupts are used, as in this template file, the 16F688.lkr *
; file will need to be modified as follows: Remove the lines *
; CODEPAGE NAME=vectors START=0x0 END=0x4 PROTECTED *
; and *
; SECTION NAME=STARTUP ROM=vectors *
; and change the start address of the page0 section from 0x5 to 0x0 *
; Refer to the MPASM User's Guide for additional information on *
; features of the assembler and linker (Document DS33014). *
; Refer to the respective PICmicro data sheet for additional *
; information on the instruction set. *
; Filename: Flashing LED1.asm *
; Date: 2009/04/20 *
; File Version: 1.0 *
; Author: Jules Lewarne *
; Company: *
; Files required: *
; 16F688.lkr *
; Notes: *
list p=16F688 ; list directive to define processor
#include <p16F688.inc> ; processor specific variable definitions
errorlevel -302 ; suppress message 302 from list file
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See data sheet for additional information on configuration word settings.
__CONFIG _CP_OFF & _CPD_OFF & _BOD_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT & _MCLRE_OFF & _FCMEN_OFF & _IESO_OFF
;***** VARIABLE DEFINITIONS
; FORMAT: [name] RES [number of bytes reserved]
INT_VAR UDATA_SHR 0x71
DVAR RES 1
DVAR2 RES 1
DVAR3 RES 1
RESET_VECTOR CODE 0x000 ; processor reset vector
goto Main ; go to beginning of program
INT_VECTOR CODE 0x004 ; interrupt vector location
retfie ; return from interrupt
; Function Name: MAIN
; Parameters:
; Description: This is the main program which is executed once the processor
; has powered up.
; The code within this routine performs some device initialisation then
; flashes an LED. This routine makes use of another routine which causes
; a short delay by sending the prcessor into a loop which decrements from
; an arbitrary value until it reaches zero.
Main
;Device Initialisation
bsf STATUS,RP0 ; set file register bank to 1
clrf ANSEL ; switch off analog-to-digital conversation system (analog inputs : off)
movlw B'11001111' ; Set Ports to I/O, TRISA register: [X][X][RA5][RA4][RA3][RA2][RA1][RA0]
movwf TRISA ; Don't I/O I/O I I/O I/O I/O
; Care
bcf STATUS,RP0 ; set file register bank to 0
movlw B'00000111' ; switch off the comparator, enable digital i/o
movwf CMCON0 ;
clrf ADCON0 ; switch off ADC module
bcf PORTA, 5
clrf PORTA ; Set all PORTA outputs to zero
bsf TXSTA,5
bcf TXSTA,4
bsf TXSTA,2
bsf RCSTA,7
bcf BAUDCTL,3
movlw B'00011001' ; setup baudrate generator
movwf SPBRG
Loop
;btfsc PORTA,3 ; Wait for button on RA3
;goto Loop
; PORTA register: [X][X][RA5][RA4][RA3][RA2][RA1][RA0]
; Care
; D0/D1 D2/D3 D6/D7
; o-!>!-o---!>!--o-!>!-o
; o-!<!-o---!<!--o-!<!-o
; D4/D5
; o-----!>!------o
; o-----!<!------o
;movlw B'00010000' ; PORTA Register
;movwf PORTA
bsf PORTA,4
call Delay
bcf PORTA,4 ; set BIT 4 of PORTA to zero
call Delay
movlw B'01000001' ; = 'A' in ASCII
movwf TXREG
Goto Loop
Delay
movlw 0xff ; set outer delay loop (change these hex number to change the frequency)
movwf DVAR2 ; memory location
Delay0
movlw 0xff ; set inner delay loop (change these hex number to change the frequency)
movwf DVAR ; incremental memory
; location
Delay1 decfsz DVAR,1
goto Delay1
decfsz DVAR2,1
goto Delay0
return
; initialize eeprom locations
EE CODE 0x2100
DE 0x00, 0x01, 0x02, 0x03
END ; directive 'end of program'
