i have enabled USART interrupt in pic16f877a and it's interrupt work but other part of my program doesn't work.
im my program i read keyboard and when interrpt is coming it show the recieved data on lcd.
when serial data is coming the progran goes to interrupt and shoew the recieved data on lcd but reading keyboard doesn't work.
just the interrupt program is working.when i push the keys the program should show the number on lcd but it doesn't work and when i disable interrupt the keyboard program is working.
i enabled USART interrup like this:
on interrupt goto USART_int
INTCON = %11000000 'Initializing the INTCON register
PIE1= %00100000 'Initializing the PIE1 register
RCSTA= %11010011
and use this instruction :
serin PORTC.7,N1200,["A"],y1
could you help me?
what should i do?
maby i have a problem in my program.
i use micro code studio picbasic pro2.41
this is my program:
define OSC 4
include"modedefs.bas"
ADCON1=7 ' convert porta from analoge to digital
TRISA = %00000000 ' set porta as an output
TRISB = %00001111 'set first 4 bit of portb as an input and last 4 bit as putput
TRISC = %00000000 ' set portc as output
' Define LCD parameters
' Set LCD Data port
DEFINE LCD_DREG PORTD
' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_DBIT 4
' Set LCD Register Select port
DEFINE LCD_RSREG PORTD
' Set LCD Register Select bit
DEFINE LCD_RSBIT 1
' Set LCD Enable port
DEFINE LCD_EREG PORTD
' Set LCD Enable bit
DEFINE LCD_EBIT 0
' Set LCD bus size (4 or 8 bits)
DEFINE LCD_BITS 4
' Set number of lines on LCD
DEFINE LCD_LINES 2
y1 var byte
y2 var byte
y3 var byte
RCSTA= %11010011
scanning keyboard:
''program
goto scanning keyboard
USART_int:
disable
USART_int:
serin PORTC.7,N1200,["A"],y2
serin PORTC.7,N1200,["A"],y3
if (y2=y3) then
lcdout $fe,1,#y2
pause 4000
lcdout $fe,1
PORTC.4=1
pause 4000
PORTC.4=0
endif
INTCON = %11000000
PIE1= %00100000
RCSTA= %11010011
resume
enable
end
delay:
for i=1 to 2000
pause 1
next i
return
RCSTA= %11010011
could you help me?
what should i do?
this is my program:
define OSC 4
' Set LCD Data port
DEFINE LCD_DBIT 4
DEFINE LCD_RSBIT 1
DEFINE LCD_EBIT 0
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
y1 var byte
y2 var byte
y3 var byte
RCSTA= %11010011
scanning keyboard:
''program
USART_int:
disable
USART_int:
if (y2=y3) then
lcdout $fe,1,#y2
pause 4000
lcdout $fe,1
PORTC.4=1
pause 4000
PORTC.4=0
endif
INTCON = %11000000
PIE1= %00100000
RCSTA= %11010011
resume
enable
end
delay:
for i=1 to 2000
pause 1
next i
return
