urgent help needed for pic16f877 programming
bythesea
i'm a beginner in pic programming and i would greatly appreciate any help given.
i need to generate a waveform using pic16f877 which looks like this **broken link removed** as shown on page3. how can i do this?
i have not done pic programming before and even though i have looked through the datasheet a few times, i'm none the wiser.
i'm using C to program the chip using the mplab and hitech-picc interface. i had been stuck for more than a week and i really hope to achieve some progress very very soon.
thanks a lot in advance
Nigel Goodwin
Super Moderator
Most Helpful Member
Well for a start you will need extra hardware, the PIC runs off +5V and you need +20V and -20V outputs. Also, assuming you need the changes from +ve to -ve to be gradual (as the diagram shows) you will also need a digital to analogue converter. If all you need to do is switch the output high for a certain time (+5V) and low for a certain time (0V) it's very easy to write the code for.
bythesea
Nigel,
thanks a lot for the reply.
the output of the chip goes into an amplifier so this is not of a big concern...yet. i'm now more worried about getting the exact shape of the waveform adhering to certain rise time and fall time.
you mentioned about D-A converter. why is it necessary?
my initial idea is to write a simple straight line equation for each portion of the waveform. (is Y = mX + c). is such an idea feasible? if so, can you guide me to how i can proceed?
ChriX
DA converter is necessary to create the gradual rise in voltage output, with digital you only get the 2 voltage levels so you wouldn't get this. But as Nigel said that's only assuming that you want your output to be exactly like the diagram, if you just use digital levels the voltage will go straight up on such a timescale so it wouldn't have the slope like the graph shows.
bythesea
thanks for the explanation..i think i'm beginning to understand
despite my limited understanding, i'm still very unsure about implementing it. my main problem has to be dealing with the time scale. for example, suppose the slope rises from 0 at t=0 to 50 at t=4. how do i implement it using the DAC and the microcontroller?
can someone provide me any guidance?
