Unresponsive Circuit Board Help
spagettilegs
I have a lighting system for my home thats controlled by a circuit board and has ben in use for 20 years now. Recently, the lighting system switches can become un-responsive and if I remove the circuit board, disconnect all cables and power and leave it 'unplugged' for several hours, then reconnect everything it starts to function normally again for a day or two before becoming un-responsive again.
I know little or nothing about circuit boards but It seems like it may be a static charge issue. Is this basically a board that has reached the end of it's life or is there anything that can be done to fix this?
Any ideas would be gratefully accepted.
It could be a failing power supply, eg. old dried-up capacitors.
Or it could be a dry joint / cracked connection, or an internal failure in a transistor or IC...
Can you post some good clear photos of both sides of the board, so we can see what components are on it? Plus the make and model of the device?
