Universal 40-PIN ZIF Socket Programming Module
UnHappy
Please share schematic and PCB layout for Universal 40-PIN ZIF Socket Programming Module to be used with PICKIT2/ICD2
Schematic will vary depending on family and individual PICs.
I need the help to program PIC16F877A & 18F4550. All suggestions on how to wire them with pin numbers and any other requirements are welcome
Go to the Microchip web site and look up the data sheets for the two chips. Under pin description you will find the pins that need to be connected to the PICkit2. Lots of other information there, by the way.
Dear friend just one last query is it possible to connect those pins directly to the PICKIT2 and program without any additional circuit or power supply
Here's one that should work with 12F, 16F, and 18F DIP parts. I designed it to use a ZIF socket or three 20-pin single-in-line machined pin sockets.
pic-programming-sockets-jpg.12798
Now if you take those two diagrams and flip the 08-20 connector 180 degrees and use a separate cable for the 08-20 devices and the 28-40 devices you could use a single 40-pin ZIF for all (just like melabs ZIF-40 adapter). Please note that while the silkscreen shows 08-18 it's actually good for 08-20.
Regards, Mike
zif-40a-jpg.6190
Nice one Mike.May be i could have some switches and remove the extra ziff sockets that i am using and also add 12F,16f capability.
