Unable to get some code to build and can't figure out why.
Chris244
Hello, I am very new to coding and have to do a bit for a course im doing at the moment.
(sorry if this is the wrong place for this)
I am using MPLAB to get a LED to move and am getting this fault, apart from this the rest looks good but i cant work out what it want me to do with the label as it seems ok to me?
.ASM 11 : Labels must be defined in a code or data section when making an object file
; U19A2T1-4.asm
; blinks LEDs on outputs in a rotating pattern, with input option to reverse direction
;Set microprocessor as 16F84
   INCLUDE <P16F84.INC>
; Setup processor configuration
   __CONFIG _RC_OSC & _WDT_OFF & _PWRTE_ON
; label 2 symbols as memory addresses for counting loops
J EQU 1F
K EQU 1E
SETUP:
       ORG 0 ;
       BANKSEL TRISA ;
       CLRF TRISA ;
       BCF STATUS , RP0 ;
       BCF STATUS , RP1 ;
       MOVLW 0X01 ;
       MOVWF PORTB ;
       BCF STATUS,C ;
ROTATE:
       BTFSS PORTA,0 ;
       GOTO RR
       RLF PORTB,F ;
       GOTO DELAY
RR:       RRF PORTB,F ;
DELAY:
       MOVLW 0X32 ;
       MOVWF J ;
JLOOP:        MOVWF K ;
KLOOP:        DECFSZ K,F ;
       GOTO KLOOP
       DECFSZ J,F ;
       GOTO JLOOP
DIRECTION:
       MOVLW 0X02 ;
       XORWF PORTA,0;
       GOTO ROTATE ;
       END
Any help would be great thank you
