Hi eto,
I would like to use motorcycle turn signals as both turn signals and running lights on my bicycle.
Below is a diagram which meets most of my needs. A relay is added as a switch to make the running lights blink when the turn signal switch is turned on.
The solution shows swapping in LEDs (which is what I will be using) and a relay for the right running lights/turn signals. A second relay would be needed for the left side.
In this circuit the running lights come on when the ignition (keyed switch) is turned on and the turn signals will work off the signal switch.
I want to add a separate switch to turn on the running lights and I want the signals to work if the running lights are on or not on.
Can I modify this circuit to meet these use cases:
Ignition on, running lights off, turn signals will work using turn signal switch
Ignition on, running lights on, turn signals will work using turn signal switch
Other notes:
-the ignition switch is just a keyed switch
-the battery will be charged manually with a charger
thanks in advance,
knurn
Other notes:
thanks in advance,
knurn
